Has anyone found a clutch slave cylinder that does not leak? I'm on my second OE style sold by all of the Pantera vendors, and it is leaking after approximately 5 months/750 miles of driving. This is getting really old, having to replace them every few months (had the same problem with the master - using a Wilwood now - no problems).  Is there a non-Pantera vendor part that anyone has adapted to fit the Pantera??
Thanks!
This is the information that was posted in the excel file for replacement parts and equivalent parts:
Benditalia Clutch Slave Cylinder:  No. X?
-  An OEM Pantera Clutch Slave Cylinder bore measured 1.000 inches (25.4 mm) and had a max stroke 1.625 inches (41.27 mm)
-  Clutch Slave Cylinder rubber boot is Benditalia #1418894
-  OEM clutch slave cylinder rebuild Beck/Arnley kit part #071-3438 is from a 80-84 Alfa2000.
-  Clutch slave cylinder snap rings are NAPA #SER 1348    ~$0.50/ea
-  Replacement clutch slave cylinder return spring: Lowe's spring assortment includes two of the required springs Spring dimensions: 5/8" x 2 1/2" x .072 Spring constant: 11 lbs/ft
Thanks!
Where is the clutch master cylinder leaking from? I just replaced mine and I can't find the leak.
The clutch masters leak at the reservoir joint and the internals start disintegrating immediately. The clutch slave drips from the boot.
Mine does not appear to be leaking there or inside of the car. I keep checking under the car, but still can't find the leak. Thanks, and I will have to look a bit harder. I found a place in New York that can rebuild the master cylinder and use new modern parts. I think I will send them my old one.
@panterapatt posted:
I don't know what Dennis has but CNC has been closed now for over 10 years as they were right down the street from me.
I won one of those CNC clutch master cylinders at the Pantera Rally in Texas back in 2015. I never used it because I didn't want to cut the original hard line that goes through the trunk. I tried to find an adapter, but it does not seem that there is one.
Rob - the only connection to leaking parts is ONE vendor as I understand these threads.   I find it hard to believe all the Alfa guys who are using quality parts like ATE or Centerline (also used by the Ferrari crowd) are having this issue.  I spoke with 2 alfa vendors and they kind of laughed at me when I brought this up.   And worse than all this, multiple Pantera vendors buy from each other.  So the problem to me is the manufacturing source IF you buy from any Pantera vendor (and let's face it, there are only 2 at this point).   For $50 bucks, I would buy an alfa unit and try it.
A clutch master cylinder has only 4 parts: an iron body, an aluminum piston, a steel return spring and the RUBBER seal. Replace your cheap neoprene seal with a Viton part and the mostly metal assembly will not leak. My Girling all-aluminum master cylinder was installed in our Pantera in 1981. No problems yet,  'cause it uses a Viton flurocarbon seal (that I added), and I change fluid regularly.
Unless of course the constant use of old brake fluid with significant water in it has rust-pitted the iron bore. The pits will tear any seal and leak. If no yearly change-of-fluid persists, a stainless steel body and an anodized piston will be required. Rebuilders add these at rather high cost. Changing fluid is cheaper....
Maybe this is helpful. I got a brand new clutch slave cylinder (never installed) together with my Pantera when I bought it. I don't know the manufacturer of it. Out of curiosity I disassembled the slave cylinder and I discovered small metal shavings inside the cylinder. I would guess remnants of tapping the inlet thread.
No wonder such a cylinder will start leaking soon after installation.
I suggest to check any new hydraulic cylinder (slave or master) before install.
I received the Centerline clutch slave (fast response time, fast shipping, wow!) today. The only thing different that I noticed from the OEM type trash slave is that the length of the body is about 12mm shorter than the OEM. I could not find the stroke specs for this slave (made by Inter Brakes, Italy), hopefully it is adequate.
I won't have time to install it for a week or so, so stay tuned.
And.... hopefully the bleed screw doesn't need 100 ft lbs torque to seal like the OEM type slave!  And, hopefully, I can cancel my order for a 55 gallon drum of DOT3 fluid, and be done with 2 years of misery on replacing these parts every 5 months.
@Rob Fridenberg did you ever get the Alfa clutch slave cylinder installed?  My Pantera's clutch slave is starting to leak (it's original).  I planned on ordering one from Centerline Alfa as well.  I notice the Alfa version has a ball end vs. the Pantera version having an eyelet end for the pin which connects to the clutch lever arm.  I assume you just unscrewed the ball end rod and replace it with the Pantera's eyelet end rod?   I have an Alfa and have been happy with Centerline's parts.  Thanks, Mike
Hi Mike,
I finally installed it a week or so ago. I just used an old Pantera eyelet end rod - I didn't bother unscrewing the ball end.
I am having a major problem bleeding it though. This is the 3rd cylinder I have installed so I have plenty of experience with bleeding (and have bled multiple brake systems on many different cars over the years). I have tried many different methods and still can not get a hard pedal. If I pump the pedal rapidly a few times, it will build pressure, but temporarily. So somehow there must still be trapped air which compresses with the pumping. I will give it one more shot tomorrow.
If I still have the problem, I am inclined to send it back. I seemed to have picked up a Pantera clutch system curse along the way.
I'm open to any bleeding ideas!! (I do not have a pressure bleeder)
Whoops, crossed reply with you : )  For bleeding the clutch cylinder (and my brakes) I use speedbleeder screws along with a Motive pressure bleeder.   Initially I only used only the speedbleeders on my Pantera and had good results.  When I bought my Alfa 3 years ago I added the Motive pressure bleeder and was really happy with it.  Now the Pantera has speedbleeders and the Motive pressure bleeder for brake and clutch fluid changes.  I highly recommend both.  At a minimum you should get a speedbleeder screw for the clutch slave cylinder to ensure you get all the air out.  A Motive pressure bleeder is about $100 and well worth it for the results you get.  Mike
@Rob Fridenberg hope you figured out the bleeding issue.  Is the Alfa Romeo slave cylinder you installed working now?
I was looking closer at my extra Alfa Romeo clutch slave cylinder alongside my disassembled original Pantera slave cylinder, and I don't think the Alfa version (https://centerlinealfa.com/cat...ave-cylinder-115-119) mentioned in this thread and other related threads on this forum will work.  The Alfa slave is, as you mentioned earlier, about 12mm, shorter than the Pantera version.  I confirmed with my own measurements (see pics below).  I think the Alfa slave will have too short of a throw to properly operate the clutch.  I've not seen anyone in the past mention actually using the Alfa Slave cylinder in my search of this forum or the email list archives. It would be nice if it does work as they don't seem to have quality issues and are made in Italy vs who know where for the Pantera versions.
Has anyone successfully used the Alfa Romeo Slave with its shorter throw?  Maybe the Pantera slave piston doesn't need the full travel of the longer cylinder?
I just ordered a Pantera "original replacement" version from one of our vendors hoping I get lucky, and it doesn't leak on me shortly after installing. At the same time I may send my original slave cylinder to White Post for a rebuilt with non-iron insert installed.  They have a lifetime guarantee and I could move on to dealing with other parts of the Pantera : )
PXL_20231122_173140272PXL_20231122_173437603PXL_20231122_173512193
Images (3)
  • PXL_20231122_173140272
  • PXL_20231122_173437603
  • PXL_20231122_173512193
From the research I did, the Pantera used an Alfa slave cylinder.  It was not a special piece built for DeTomaso.  The specs on the original slave were An OEM Pantera Clutch Slave Cylinder bore measured 1.000 inches (25.4 mm) and had a max stroke 1.625 inches (41.27 mm).  I researched several Alfa part numbers including the Centerline piece but did not call them to investigate actual dimensions of bore and length.  ATE makes a unit that is supposedly correct dimensionally and the Centerline unit is made by someone in Italy.  Again, I never went the final mile to call them and get measurements as my CNC unit works fine.  Not sure the dimensions of what Rob actually got.
I still have the soft pedal problem. I will have my wife help me with the 2 person bleed one more time.
I did mention that the cylinder was shorter by about a 1/2 inch, the bore is identical.
I took some video of the clutch pressure plate moving while pumping the pedal (which gives me the hard pedal) and the plate movement seemed similar to older videos I have taken. So, I think it will work, when and if ever I get a hard pedal.
If I do not have success, I will try to return/exchange it. I feel like using a Pantera vendor part is a 5 month solution based on my sample size of 2.
I was speaking to Scott at SACC and he mentioned that his clutch slave is still dry after 18 years - I offered him $1000 for it.....
Hi all. I measured the throw of the Alfa cylinder with the piston installed and it's 1.287 inches (32.69mm) while the Pantera cylinder is about 1.625 inches (41.27) as @panterapatt mentions.  Both the Alfa and Pantera pistons are the same length. (pics below). So, the Alfa version will definitely have less stroke available than the Pantera version.  But, as @Rob Fridenberg mentioned, it still seemed to move the clutch the same amount.  Rob, let us know once you get the hard pedal and then how it works.
Seems to me if this was as simple as just using the shorter Alfa Romeo slave cylinder then the Pantera vendors would not have invested in the longer Pantera aftermarket versions to sell.  They could simply buy/repackage Italian made versions already being produced for Alfas.
Thanks for this discussion as I'm looking for slave cylinder options going forward since CNC and stainless version seem no longer available.  I do appreciate and like supporting our vendors but sometimes I've found other options when the after-market parts aren't panning out.  Thanks, MikePXL_20231122_190453776PXL_20231122_190401882
Images (2)
  • PXL_20231122_190453776
  • PXL_20231122_190401882
