Both of mine (late '74s) are slip fit and is held in place with a C-clip. The slave bracket may have some idiosyncracies due to its handmade nature. It may have been painted too much reducing the I.D. for the slave cylinder. I can't speak to the earlier Panteras.
marlinjackThe Machinist #5723 AMARGOSA MACHINE 'Running on Empty- Middle of Nowhere'
...When I changed over to the 'Long Throw' Slave Cylinder, sold at PIM, it was a 'little' loose in the Stock Mount ('74L). I chucked it up in the Lathe and Knurled bands into the Aluminum Body, to increase the Diameter. Fit is good now, and the knurling does Not show.
