There are two plastic wings that hold it in place. It looks like one or both of yours are snapped off. This cable in my Pushbutton car had a problem with the chrome peeling off. I got the last one that Wilkinson had. It was used and one of the wings was missing. I improvised with some epoxy (or something like that). Maybe you can use a small hose clamp formed into a square shape to secure it.
That's what I like about Pantera people, they don't lose it when you use something other than OEM stuff to fix things. I have been around Mopar nerds that were bragging about that the air in there spare tire had factory air in it. That exactly what I will do,thanks.
I just posted about finding an old assembly. Felt lucky to find it. The assembly that I picked up also had a conical shaped spring that fit over the wings and took up the slack. see photo....don't know if this is correct or not.
