I have a series III Deauville. It was always working fine, but now she is running hot. I have reworked the heads, putting steel valve seats in, and had had a good look at the engine. The factory hones were still visible and the engine looked in good shape.
But now there are cooling problems. When cruising a 70 Mph the fan's are constantly on. That way the themp. of the engine will be 100C ( checked that with infrared Thermometer ) The thermostat is opening exactly at 84C and the fan's will turn on at 95C and off at 90C.
So I have replaced the radiator by a new one ( copper radiator ), replaced the waterpump, thermostat, and cleaned the watersystem. Thereafter I checked the radiator for dirt, but it was clean.
In front of the radiator, is the AC cooling unit same size, and in front of that, there is a transmission cooler, normal small size.
Oil themp is normal around 100C.
There is more then enough flow through the radiators.
Anyone an idea what's going on?
grtz Arno
No the engine sounds fine, and runs real good. Also the timing is right, and the exhaust heathers don't get hotter then normal. The gaskets may be the problem, but if I look at the pictures when we did it, they are placed the right way.
Point is that if there was a blokkage in the watersystem, there would be a low flow through the radiator. That way the fans would never be on, because the water runs so slow, it has time enough to cool down.
But now, the fans are alway's on. So the engine produces to much heat, or the radiator is not capable of loosing the heat. It is a double flow radiator. That must be because the inlet is at the top, and the return right below. I am really puzzled what's going on.
Well checked the gaskets yesterday, and the were mounted the rightway. But also, If the were mounted wrong, there would be no or restricted flow through the heads and cilinderbanks. The cooland would then be boiling at the rear of the engine and real cool at the front. That way there would be cold or real cool coolant entering the radiator. The fans should be off all the time, and really strange noises should be coming from the engine.
There can only be two problems, the engine is producing to much heat, or there is not enough heat transfer from the radiator.
The fans are on most of the time, so hot coolant is entering the radiator all the time, that shows a normal flow of the coolant. Also when the fans are on, they produce a big volume of really hot air at both of the fans. This shows a good routing through the radiator, and a good flow of air through the radiator.
Am I right?
So maybe the engine is producing to much heat. the timing is right, the gaskets are right, the only thing that I can think off, is that I also changed the oil, to MOTUL 300V full syn. racing oil. Had anyone heating problems when using full syn racing oil?
Arno
I had a problem like that before. I discovered that the inner lining of my top radiator hose had come loose and was partially blocking the water flow, almost the entire length of the hose. I had already replaced many cooling system parts and only discovered it when I was removing the engine and happened to look inside the hose. It was not visible from outside the hose. Just a thought.
OK, I found the problem. It had to be stupid, and it was. In Holland we have to mount big licence plates at the front of the car as well.
It has to be mounted on the front bumper. On a series III Deauville there is a rubber strip along the bumper. So you can only mount the licence plate sticking out off the bottom, otherwise it will look strange and not in place. Now it turned out that the 2 1/2 " sticking out, acts like a deflector blocking the flow to the bottom half of the radiator. I removed the licence plate and now it is OK.
What did I do before?
Changed the radiator, waterpump, thermostat, pulled the heads (there are felpro gaskets that have the same corners all around ),changed the oil and cooland.
The real fix took 45 sec's roll on floor
