...Well, You did ask for the 'Average'! Now, try this: L Model Curb weight is 3200 LBS. Weight distribution, front to rear is: 41-59 (if you believe the 'Road & Track' test data).
Weight in Front = 1312 LBS. (656 per side, average). Rear = 1888 LBS. (944 per side, average). Add the four corners up and get 3200 lbs. It's up to You to realize Each Corner, Exactly!...
