Thought I’d share some pics of the current progress that I have had with my 9yo son.
A big thanks to Corey Price for helping me on multiple levels with the build. Pantera Performance has been helpful as well providing CV joints (soon) and a wealth of knowledge; Quellas are so nice to talk to regarding specifics.
Been waiting on a Holley HP tuner for 2+mths… hoping for end of this month🤞🏼
Images (3)
  • IMG_9497
  • IMG_7141
  • IMG_9512
The engine looks good in your Pantera.  Getting me to think about an Coyote engine swap for my Pantera.  Can you share what motor mounts and all other hardware you needed to use for the swap and all of the obstacles you had with the engine swap or was it straight forward LOL.  Do you have to go with a cable shift linkage or keep the standard.  THanks,
There is a lot to it. On the list of difficulty, I’d rate it very high. Multiple changes need to be made, and multiple components purchased. It is a phone conversation vs a forum tutorial. I did consider doing a YouTube on it and may still, but I’m waiting on parts (one of the difficulties) and not complete. You can go with cable shift or CV’s. Either will work. I say Skip the cable shift bc the gate is awesome and is part of the personality of the car. U-joints vs CV’s don’t make much difference in my mind….arguably an improvement without taking personality away
I love the Borla intake with the TB's at an angle. The system works great too. The last time I was at Autotrend EFI in Diamond Springs, CA they had that exact setup on a Coyote in a 1950's Ford pickup street rod. The TB's were Cerakoted black and the manifold was gray. I should have taken pictures. Looked deadly and ran even better.
Thought I’d give an update. Just mounted the new and improved Bosch 044 (sku 0580464200)  in the rear left wheel well of the car. I’ll be placing a “rubbish guard” over it. I don’t ever plan on driving in the rain, but you never know.
One of the most difficult parts of this is getting the accessory belts to clear the shift rod. Many hours spent on adjustments. I do think that the accessory belt on the Ford F150 is more horizontal than the mustang coyote, so it presents a little bit of a challenge on multiple levels, which I welcomed.  This is a gen 2 F150 motor for lots of reasons. Primarily I knew I could get a used one and feel good about the lifetime of the motor bc it’s rare you see farmers doing burnouts in their F150(leave that to me now😂). Secondarily, I knew I could play with it and if I lost steam on the build I wouldn’t feel so badly about spending $15k for just the motor….oh… and I limited myself to 400-450 hp bc we all know it’s easy get whisky throttle and I have kids I should watch graduate high school…and 3rd it has the same firing order as the 351C so I hope I can emulate that awesome Pantera sound with a modern(more reliable and lighter) platform.
I can thankfully now say it’s on the downhill.(I’m waiting for a computer from Holley still).
looking forward to hearing it run soon!
IMG_0589IMG_053371296029849__721EE8A6-A50F-4442-8130-58E028E446DBIMG_0511IMG_0509IMG_0535IMG_0531IMG_0534IMG_0591
Images (9)
  • IMG_0589
  • IMG_0533
  • 71296029849__721EE8A6-A50F-4442-8130-58E028E446DB
  • IMG_0511
  • IMG_0509
  • IMG_0535
  • IMG_0531
  • IMG_0534
  • IMG_0591
That worked! No leaks! Recently purchased the coil covers and a vinyl kit to inset flat black letters… took 2.5 hours to inset the letters😫. There has to be an easier way, but looks so good. Covers came originally black and then I painted them to match match the block. Happy Labor Day! Here are some car porn pics . So sexy…  I have to determine what I’m going to do with the rear deck lid. I have about an inch I would have to cut out of it to get the rear of the stack to clear.  It just seems painful because it is a beautiful deck lid. Maybe I  should get a fiberglass one? Thoughts?71530850441__A340A53E-FA0E-4B87-970C-864A74863283IMG_0894
Images (2)
  • 71530850441__A340A53E-FA0E-4B87-970C-864A74863283
  • IMG_0894
Please strongly consider modifying a fiberglass decklid instead of a nearly irreplaceable steel decklid.
instead of just cutting notches for the stacks, a much cleaner look can be accomplished by trimming the entire edge a sufficient amount to clear the stacks.
The first time I saw this, I was scratching my head, wondering how he had managed to move the engine that far forward until I realized the stealth manner he had clearanced the decklid.
if you do cut the steel decklid, save the removed pieces in a clearly labeled and identified bag or box and do your best to see they are kept with the car for a future owner
No first-hand knowledge, so no recommendations or certainty on who carries what.
P.I.M. motorsports, Jerry
Panteras by Wilkinson, Steve
pantera parts connection, Larry Stock.
there have been some small production, true carbon fiber panels being made for our cars, a search in these archives might provide some contact information.
Be aware, most of what you find being described as carbon fiber will just be a carbon fiber overlay on fiberglass pieces
A word of advice. Get some kind of guarantee as to the fit of the fiberglass deck lid. If PIM won’t give you one, cancel the order. I know of one Pantera owner that spent thousands of dollars in body shop time, just getting a fiberglass deck lid to fit. You’re probably assuming you could just paint it and bolt in on but I doubt it’s that simple.
With a much lighter fiberglas deck lid, you'll need far softer decklid shocks to open it. Stock strength shocks might warp the thing over time. With some aftermarket decks, one shock (mounted on either side) will open the lid just fine. Also helps to clean up more engine bay clutter. The swap loos fine from the back- how does it drive?
The computer is on the way! I was starting to think I’d never get it😬. Ordered in March. Some other updates. I had the rear firewall reupholstered. It’s worth noting that some time should be spent evaluating how the piece should be fabricated to close the firewall. I’m now on my 3rd version of the piece and made this one out of aircraft aluminum at the plane shop. The issue that I have now, is the upper water hose needs to be shortened a little and I can’t use the super sweet t-bolt clamps there bc they hit. It’s still going to be tight, but I’m going to run it like that until I get a wear spot, and then emboss with some cool tools. Hoping I can leave the upholstered part flat without a bulge.
Hindsight, I would have re-fiberglassed the top of the panel that hooks to the firewall PRIOR to reupholstery, but I didn’t even think about it, so had to work backwards a little bit to avoid redoing upholstery. If anyone wants a nice custom firewall piece, my old one will work for someone who just edits the top of the fiberglass prior to upholstery(the ideal way to do it)IMG_1695IMG_1696IMG_1697IMG_1698
IMG_8932
Images (6)
  • IMG_1695
  • IMG_1696
  • IMG_1697
  • IMG_1698
  • IMG_8932
  • IMG_8932
Coyote is all wired up and idles! Decided to Go with HP computer to be able to have L&M cams and 8 stack tunable.
I placed I wired the fuel pump and Tach adapter from Pantera electronics through the computer.
big thanks to Jon Haas at Pantera electronics for helping me through this. Tact adapter is perfect, and was super easy to install.
We are going to tune it this week, hopefully.
The fiberglass deck lid from PIM wasn’t a slam dunk. I had to remove the weatherstripping and adjust the rain gutter rails, where the hinge mounts to get it to slide forward and latch. We have spent hours trying to get a good alignment with chims and wrap our brains around how to not grind on the car pinch welds in order to get it to fit. The idea was to use this deck lid and be able to place the other deck light on if I get rid of the 8 stack. Haven’t adjusted/cut/ground the lid at all bc might have to return it😥 and cut the flawless stock one.
Does anybody have any experience/ideas how to get the “wing part”/rounded forward corner as it turns into the roof line higher without bodywork? Both sides are sub 1/4 inch. See pics. Thanks!
Images (3)
  • IMG_2548
  • IMG_2660
  • Resized_20231202_164347
I had a feeling you'd run into these issues with the fiberglass decklid. They are fine for a race car, where weight is the primary concern and fit is secondary. It is always a ton of work to get them to fit like an OEM steel decklid. Just return it, if you can.
Cutting a notch in the original decklid isn't "the end of the world". Just make sure you save the piece you cut out. There are lots of good sheet metal fabricators out there, that could weld the notch back into the decklid, so no one could ever tell it had been cut out.
I'm surprised that you needed a tach adapter for the HP. My tach worked fine without an adapter, with my Holley Dominator ECU. I assume the tach output on the HP is the same. Oh well, as long as it works!
Hopefully, we won't have to wait too long for a posting that has a video attached to it, with sound!
Call Larry Stock at PPC and ask him who he had build a 6061-sheet deck  for a guy racing in Europe a decade or two ago. As I remember, it was complicated but I never saw the thing.  The GR-4s had aluminum door skins crimped onto stock steel frames, but DeTomaso never went further with hood & deck, maybe because "other" race factories in Gr-4 lobbied a weight that didn't require more aluminum.  Allessandro never spent money he could save....
@davidnunn posted:
Thanks David! I tried again to get it to fit and no go for like the 10th attempt(spacers, adjustments of rain rail, latch, trim, etc. An exercise in futility, but needed to take a video of how far it was off for PIM so they could maybe help me get it to fit without bodywork. Good buddy is an aircraft mechanic who specializes in bodywork on aircraft(metal, fiberglass, composite etc). He said it's a no go again, and got a little irritated when I asked him to help me try again...haha. You're right, it's close, but I'd have to do a lot of grinding and add fiberglass to all the edges etc... They should over size these a little b/c much easier to cut down the edges than add. I'm going to have him cut out the notches in the deckled. He recommended following the contour of the 8 stack into the decklid.
Dave at Autotrend EFI will be remotely tuning it as so as I get my Synchrometer; should be here today! Video to come!
@USCDOC13 posted:
Time to button it up!
IMG_2842
With all the beautiful installation work and custom fabrication of the new firewall cover, I think you would want to get rid of the manual heater shutoff valves, which will require removing the interior panel and firewall cover to open or close, and replace them with an electric valve so you merely hit a switch on or under your dash.
Here's the Thermotion 354-69494 that someone else on this list installed: https://www.amazon.com/Thermot...69494/dp/B07119TY9Y/
Available for less at: https://www.truckac.com/heater...354-69494-t4037.html
And even LESS EXPENSIVE direct from Thermotion: https://www.thermotion.com/4-p...l-valve-pn-354-69694
I'm thinking of installing one of these myself.
Following are some other inexpensive electric heater bypass valves.  Note that I have NOT verified if the ports on the following valves are sized correctly for our heater hoses.
4-port valve from a Cadillac: https://www.1aauto.com/chevrol...hcx00004/535137/1997
Or a pair of these from a Ford F-350: https://www.amazon.com/KarPart...495AB/dp/B09HY2PBW9/
This looks like a generic version of the same thing: https://www.amazon.com/Four-Se...Valve/dp/B001TPSXDG/
