On my 73 single Pod Dash I have 2 Lamps, one Amber and one Red. The Amber lids up when I pull the Parking Brake and supposedly if there is a discrepancy between the pressure on fwd vs rear lines sent from the OE shuttle Valve. The Red one should be the Brake wear warning. I was thinking to move the Wire from Brake wear over on the Amber Lamp so that all Brake related was on same Lamp and then use the Red Lamp as a "low Oil Pressure" Warning via a new pressure Switch on a Tee by the Pressure Sender. My question is if anyone has gone down that Road with success?
Jan
