I would like to take some detail pics and try doing vids, BUT the temptation to just DRIVE overcomes.
5177 is now stored in a different building rather than the shed it stayed in 20+ years.    I added a centering line and delineators to help keep me straight.
open the rollup and fire it up, walk the exit to ensure it is clear
back off the concrete pad and into the yard.   did show, but I have to angle due to transition and spoiler draggging.
down the long dusty path to the paved road.
head into town and first fill up of 91 non-alcohol.
went for about an hour just cruising the back roads.   the engine seems to like ~2200 rpms, giving me ~55 mph in fifth.   I found listen to the tone makes an excellent "cruise control".  Having to down shift as approach a stop is a little strange, but not engine braking but just keeping rpms up without just coasting.
Pulled back onto the dusty drive.  I got the Panther mascot, but no "Farrah Fawcett"
can't wait for tomorrow's excursion.   Would like to drive to diner, but between the altornator might not keep up with headlights and more so my night vision I won't try
Images (6)
  • blobid0
  • blobid1
  • blobid4
  • blobid3
  • blobid5
  • blobid2
trying to figure out how to take and edit vid.    don't know why out of focus.
cold start   https://youtu.be/mMZrxXaltxY
I discovered a driving idiosyncrasy I don't recall hearing before.
when I released the clutch, the toe of my shoe was "grabbed"
does my steering knuckle look like it is the the right place.   This is a new piece.  any comment about brake pedal.
  • blobid0
500 miles today!   no trips just loops around neighborhood.
the plan is, make notes of what needs to be changed, then back to shop after first of the year.
i am having dexterity problems and finding first is a challange for me.   i took a cabinet hinge and made a reverse lockout.   WHAT a differance to be able to push to left and pull down.  I now don't have to hold clutch down at stop light.
THANKS to ebay's "barbaram442"  i now have a working lap and a set of 72 shoulder belts.   i used a7/16-20 x 1" bolt for anchoring shoulder belt.
those belts are a pain.   lap belt "locks" and keeps tighting and can't pull out till full retract.   the shoulder has to be hooked in lap before buckling
  • blobid0
Hey John!  Glad you got your car back.  !  Is is overheating?  The air deflectors made a difference with the stock radiator at road speeds.  I struggled with overheat problems for 10 years before we figured that the orifice under the thermostate was too big and never would stop off the bypass.   I see your brake pedal and I cut the bottom corner off mine and it cost nothing and makes a huge difference when driving!
  • DSC00756: cut brake pedal
Thanks for the "experiances" lessons learned !
the driving tecnique and muscle memory going from one car to another got me.   I hopped in the TR6 to run to town for gas (and keep battery up) and almost wrecked aproaching stop sign,   all THREE pedals responded different.
as for brake pedal, the fact that it was lower than throttle.   (opposite on TR6).    I think I have a tecnique that will work good as I continue to use it,   that is keep the right heel on floor and "turn" foot from throttle to the lower brake, using between toes and ball.
sort of same thing with clutch, keep the heel on floor (inline with clutch) then raise slightly to use between toes and ball, instead of arch.
both of those have me thinking about a "heel rest".    shaped something like wall mounted bottle opener!
I have not removed tube to even look at the AC condensor and its sealing for air flow.    (I had wanted the "L" trunk profile made like earlier car for more air exit flow, but didn't want to delay in driving)
"I" think the side shields are needed but didn't want to be more "picky" for taking care of any items noted during my driving.
With the car moving, I did have one segment where I "thought" the radiator temp was not dropping and the fans stayed on.   that was based on battery voltage stayed low at speed.    I have three points in coolant system for measuring temp.   the Holley Sniper sensor and display are at the block position, the console gauge and its sensor in the water pump inlet (radiator return) and the idiot light switch in swirl tank (can't recall its setting) and the coolant fan swith in the radiator exit upper side tank (i also don't know its setting but think I reqest about 160"
Most times at road speed sniper temp is 185 to 190 with console gauge abot 170 (just right of 160 mark).   I have very little time in stop and go traffic, temps do go up.   have not been there to see if temps level out above 200F.   (currently running 7psi cap (on pump suction).   Shutting down HOT after slow roll down drive, there has not had gurggling as coolant temp rises during heat soak.
another question. . .
When tighten shift linkage lock nuts, holding Gate in center L/R in 2 / 3 path is done, BUT how do one hold the trans shifter shaft?    ( In my long ago thinking bouts, I drew up a radial fine adjustment "clutch")
question . . . can the shifter's gated plate be removed, or does it hold something together?
after last week's adjustment of the turn buckle, the as left was not really that good, but all gears could be selected.   after hour drive, i am not able to select fourth and fifth takes about as much force as i want to use.  definately feel the shifter and gear box detents are not aligned.   not sure if the "new" linkage has hysteresis/clearance issue.
thinking if i loosen / remove gate i can ignore the shifter detent and at least drive some more.
When tighten shift linkage turnbuckle lock nuts, holding Gate in center L/R in 2 / 3 path is done, BUT how does one hold the gearbox shifter shaft?
do the lock nuts need to be gorilla tight or just good enough
  • blobid0
