Anyone have an accurate one?
I looked at Pantera Place but they don't have one.
Also need to identify the wires to the brake warning switch on the dash.
What I have is not matching up with the color code in the diagrams.
quote:Originally posted by jb1490:
Doug,
The dash mounted brake warning light wires should be either gray (+12) and pink, or white (+12) and black.
Do you need wiring info for the emergency flasher or the hazard warning switch? If the flasher, is it a 3-wire flasher or a 4-wire flasher? If the switch, early or late, or are you replacing an early switch with a replacement (late) switch? Let me know exactly what it is that you need.
John
quote:On the brake warning lights I have two grey and two white with black stripes coming to the light socket.
quote:I need a light socket to fit the speedometer.
Anyone know if they are still available and/or what the aftermarket part number would be?
