We're going to pull a clevland on the weekend. What size bolts do I need to mount it on an engine stand? Can I use the bell housing bolts for this? Thanks in advance
Originally posted by INZOWHO: We're going to pull a clevland on the weekend. What size bolts do I need to mount it on an engine stand? Can I use the bell housing bolts for this? Thanks in advance
Doug M
7/16-14 UNC 3/4" to 1" longer than the through holes in the mounting arms of your engine stand.
