The Euro lenses (red/yellow, with white back-up) will bolt onto the base for the US red-only (with backup) version. The bulb orientation is identical. The bases interchange perfectly, too.
Thanks for your help Jack and Co. You are much appreciated by youngie(42?) and not-wiser bucks like myself,and more I'm sure unsigned. This new PI message board is a great resource for all,tip o' the hat to the crew!
