Good Evening,
I was able to get the PI Motorsport headers installed and sealed.  Turns out they hug the rear springs really tight.  No interference that I can see but once the suspension moves that could be a different story.
Due to the headers being different than the original Hall Headers it had I'm going to need an exhaust made from the header collector back.
I believe the exhaust I have could be Mind Train?  See attached.  They sound really good but will need to be modified if I keep them.
Since I need fab work anyway, unless I go back to the Hall Headers, what does everyone recommend?  Keep the current exhaust tips or go to something like Borla, etc?
I know everyone has an opinion so looking for a few options.
Thanks,
John
#2551
  • Muffler
The mufflers pictured above are Hall Big Bore. The mufflers of choice are Pantera Performance Center's stainless steel GTS style. They have matching headers too and it's been reported they fit perfectly. Sound great too. Since they don't fit, why not return your PIM headers and buy PPC's complete system.
https://www.facebook.com/Pante...eos/1024307807694298
312337354_599432325312213_5100750589764167600_n
  • 312337354_599432325312213_5100750589764167600_n
The cars suspension is super tight, to the point that it didn't sag when i installed the engine and tranny. I need to lower the car next, so probably a good time to check the travel.  My guess is there is a about an 8" gap between the top of rear tire and fender.  The car was on an AZ storage building for 35 years before I found it so I'm guessing the shocks are dried out and stuck in place.
Thanks for the advice.
John
Dennis' mufflers are beautiful and not loud and are far better than my previous Hall big bores with their "cherry bomb" glass pack sound and drone.  That said, Dennis' mufflers are just that - mufflers.   You need to fabricate pipes from the muffler to the header.   I do not believe he sells a complete exhaust system - you will have to ask him but he did not when I bought mine.  Here are mine installed.
  • mufflers
Thats a good idea.  The driver's side clears fine on mine, but the passenger side definitely hits the CV axle.  I also thought one could use the oval shaped pipes to snake thru the mess but at that point you may as well have a shop fabricate a complete system.
Hopefully Dennis comes back with a reasonable quote and I can proceed.  Otherwise, I'm thinking of putting the Hall BigBore headers back on and just drive it for a while.  Project has been 13 months in the making and really itching to take it for a drive.
Thanks,
John
I have the Pantera Performance mufflers on my car.  They are well made.   I agree with Chuck and Larry, these are not quiet mufflers, or it least they are not on my car.   I am not sure how much the motor size, headers or exhaust pipe size can affect the volume so that could be a factor.  When I got these mufflers, I looked through the inlet and you can see right through them, so they aren’t restrictive.
Hi everyone,
I have a GTS exhaust in my car. The mufflers are straight through with wool surrounding  the pipes.
As soon as the car rolls in the open it is tolerable, but at idle between buildings it is really loud and has a nasty drone.
What are the most quiet mufflers currently available, that aren't hurting flow too much?
  • AGA_Pantera
here is a factory drawing showing axle orintation.   This was a MAJOR aurgument I hac with the ex-project manger.   He insisted the smaller splined shaft was lighter and thus SHOULD be as reversed (less sprung weight ?).   I weighed and the larger diameter HOLLOW tube end is same weight as smaller diameter solid shaft.   when second manger got to installing exhuast, he called to see if I would mind if they reversed them to the correct way!
As for BALANCE.   be sure the splines have the matching arrows in allign.  the phasing of the ujoints cause an jerk in rotation
  • blobid0
@GeorgS posted:
Hi everyone,
Sorry to bother again, does anybody have a suggestion?
Hi GeorgS,
I have Wilkinson GTS muffler (diameter 2.5 in) and I am doing tests with Car Chemistry 3DI25R inserts inserted before the silencers. On my exhaust I can only put 2 discs (instead of 3 maxi). Without the inserts I had around 85 dB at idle and 90 dB at 3000 rpm, with the inserts (without the washers), I have around 77 dB at idle and 87 dB at 3000 rpmis a gain of about 3 dB and I did not feel any loss of power. The inserts are supplied with washers that can be welded onto the tubes to further reduce noise.
Here's real data on your inserts.  18 hp loss for marginal noise reduction.   The Wilkinson system was "supposedly" designed to remove the significant hp loss created by the original Ansa and Ansa GTS mufflers.   Gary Hall cut GTS cans open and removed all the guts which significantly increased the HP.  Not sure anyone ever cared about the noise levels from a Pantera as most posts here ask "how to make  my system louder".
https://www.ffcars.com/threads...-db-difference.4850/
@GeorgS posted:
What the Wilkinson or Pantera Performance mufflers will do for you is be a bit quieter and get rid of the dreaded drone. Unfortunately, it seems nothing bolts right on. Some fitting and fabrication is always required. Dennis’ mufflers require the mid-pipe to be fabricated and Wilkinson’s need to be modified to fit properly.
