Originally posted by 73 l:
question if you were running a .50 lift @1.73 then what lift would these 1.80 ratios make?
@ .500" valve lift with 1.73:1 ratio, you have a cam lobe lift of .2890".
If you switched to 1.80:1 ratio, you would have a .520" valve lift.
