I have an early cat, #2036. If the diameter of the welded banjo fitting at the top of my fuel tank is 5/16, I assume that that is also the diameter of the fuel pickup inside the tank. Would running a 3/8 line from the banjo fitting to the pump to the carb increase the flow, or is it limited by the 5/16 tank supply?
Does anyone know the diameter the supply tube of Wilkinson's upgrade to the combo fuel sender/ fuel supply?
