Probably a stupid question, but if I test Ohms on the two tabs at the top of the unit where the sending wires attach, while installed on the car with no wires attached, and the tester says OL, does this confirm the sender needs to be replaced? I assume if it is working and the tank has at least 10 gallons, there should be some resistance. Maybe ~170 ohms? Thanks, Shashi
