It may be able to be fixed rather easily. I recently tested mine, and found an open circuit. It was caused by the rivet that attaches the wire (on the underside) to the spade connector (on top). I supported the rivet on the underside, and gave it a smack with a punch from above - problem solved. Worth a try.
Originally posted by Cuvee:
Well, pulled the sending unit out and found the Float Full of Fuel and the wires to the sender were switched. My friend had a extra Sending unit so I put the good float on, put it back together and so far all is good!
Now...does anyone have a part number for just the Float? Fiat or Alfa?
I use a piece of cork, from a sanding block.
Simon
