I found a replacement pedal from a local Pantera owner that had had one fixed. I installed this but managed to lose the spring. Also there is no place on the arm
to attach the spring. I have tried several attempts to buy a replacement spring that looks like it will fit but so far no go.
I can't seem to find one strong enough to
pull the pedal back up. Most of the places
that sell springs sell very heavy springs for other things. Where can I find a good replacement spring and does it just clip around the pedal shaft? Seem like there should be a tang or something to clip onto.
Thanks.
