I routed the cable from the drivers side of the equalizer pulley to the passenger side e-brake and vice versa so the sheaths crossed under the transmission and left the sheaths hanging loose unattached.
Then I set the adjusters to get the handle effort I liked in the cabin and pulled it up hard to engage the e-brake. I made a couple of tabs to hold the cable sheaths as closely as I could to where they wanted to be under tension.
It significantly eased the radius of the bends in the e-brake cable sheath where they turn 90 degrees and head to the caliper from the frame rails. I believe the resulting loss of friction has left me with a much more effective e-brake.
Chris,
The clamp goes as far aft as possible, before the cables start to make their turn towards the calipers. If you cross the cables (like Larryw and I have done) then that clamp won't fit. The left side cable goes under the right side cable, and acts a like a support (sort of) for the longer right side cable.
I don't have a pic.
John
