George has some good pictures of the Boss/HO balancer posted in his Facebook Engine pictures also.
@ JTPantera. A lot of the Cobra balancers needed to get sent out for rebuild. I have heard of none of them failing after the rebuild.
You want to rebuild before it fails...the balance ring tends to slip on the hub and can be off 30 degrees.
This is a good shot of the Boss/HO balancer installed. You can see how thick it is compared to everything else. Even the Romac isn't this thick and heavy
Incidentally, this is the aluminum '68 Ford Cleveland "Indy" block that I mentioned in the discussion about the pressed in lifter bushings. It was repaired in the lifter gallery. I do have a picture of that (somewhere...everything is somewhere?
) . It appears that the lifter bushings came loose and wiped that portion of the block out.
That's a really good modification but just like taking a prescribed medication, there can be possible side effects and there are real risks involved. Doesn't matter how small. The risks are still there. Someone does win the lottery you know? One needs to balance their own risks and position themselves as best they can?
The welding in there is extensive. The block really is now best used as a display. Too bad. Not many were made and even fewer have survived being grenaded by the big time Pro Sock racers back in the day?
Apparently Ford GAVE guys like Nicholson and Gapp&Rousch aluminum blocks to "test". I guess they figured if they survived those guys, they were ready for production...and that never happened. Still haven't seen the matching aluminum heads for this block.
Those heads in the picture are the B351 Motorsport heads from about 1985.
Picture is from Jeff Burgy. Engine was for sale this time last year.
