Rene, I think what you are illustrating is how well the Yaris RHD EPS applies itself to the Pantera? This is what I was stating previously.
It struck me that of all vehicle "add on component systems" that the EPS must have been conceived of as a modular one? No one specifically designed for any one particular application.
Just a concept of sliding up and down the chart selecting the best size and orientation to be applied to any one application. Almost like looking at a tire application chart?
The variation from vehicle to vehicle would be in the brackets needed to adapt it to a specific vehicle chassis. Sourcing one being similar to what Detomaso did with the Pantera in adapting the Capri column out of the Ford Euro stockpiles.
The Yaris just emerged to me for the Pantera as one, "checking all of the boxes" comprehensively.
As I recall, the Prius is a larger basic unit then the Yaris is and that was the reason that I went with the smaller Yaris RHD version?
Space available in a Pantera is absolutely minimal at best.
I don't recall if the Prius had a choice of a LHD or RHD orientation like the Yaris does but it could simply have been that when I found the Yaris RHD, I stopped searching?
In the Pantera, the boost motor needs to be on the left side of the steering column.
The managerial decisions now in our era are largely made by analyzing research data. That gives us the best likelihood of success but that also is based upon the initial criteria we stated as the issue needing an improvement or complete solution to.
The Pantera never had power steering to begin with. Many still would say that power steering is not necessary. If that is so, why would a system with 30% more power, like the Prius, be more desirable in a vehicle of similar size and weight to the Yaris to begin with?
Don't forget that with the emergence of the automatic variable GPS boost control, boost to the servo motor of the EPS is being ramped down to completely eliminated by 50mph. This to eliminate the possibility of over boosting steering assist at high speed, further emphasizing the lack of necessity of more power steering boosting?
I'm working on a narrow fender car with a maximum of 8" front wide wheels, a 235-50-15 maximum tire profile and little or no need to overcome bad scrub radius.
I'm aware that the wide fender cars have less then perfect front steering geometry and with the possibility of 10" wide wheels and 285-40 profile tires COULD possibly benefit from more assist into much higher speeds?
There I would yield to the possibility of being able to use a higher power motor but that might not even be necessary if using the manual boost control instead of the automatic boost reduction GPS device?
The automatic boost control ramps down boost v vehicle speed. The manual control does not vary it and remains constant according to the setting you have it on.
Size wise, from what I have experienced, the Yaris is about as large a basic unit as can be fit into the Pantera and the smallest on the market?
I can't compete with what results Toyota can attain, so why not let them do the research, specs and development?
All my "engineering" is done with a LHD Pantera in mind. I don't know how that will change with a RHD Pantera?
