The gage on the dash quit and needs checking. A second gage at the block shows that I have oil pressure. Before replacing the dashboard gage I'd prefer to test it by removing it from the dashboard and wiring it directly to the sending unit without long wires between the two. The sending unit has one black wire and is grounded to the block. The gage appears to have one black wire, two pink wires and one black and yellow wire for the light bulb.
What are the pink wires doing back there? do they effect the gage performance in some manner? Do you have a wiring diagram?
I'd also like to replace the bulbs with LED's. Do they exist?
Thank you,
Tom
