I have the car up on a Quick Jack.  On each end of the car I also have a 3 ton jack stand.  The Quick Jack is lowered onto its stops. There is weight on the Quick Jack pads as well as the jack stands.  When I shove the car back and forth, it seems stable.
Do you think it is safe to work under this car?   I will be disassembling its motor mounts for inspection.
Thank you for your input.
Images (2)
  • mceclip0
  • mceclip1
