I put them on my car. The quality is really nice. They took quite a bit of careful fitting to get them tight to my car. The outer edges do not fit tight to the car, they stick out just a little bit. It looks like it is supposed to be that way actually. I wonder if they are modeled after wide body car bumpers? All in all I am happy with them and I like the stainless look over chrome because they match the rest of the trim on the car.
Yes, they are advertised on E-bay BUT ...
1) the picture used is of an early car but the bumpers are for later cars.
2) I have the manufacturers contact info (Vietnam). The UK address is a front.
3) The manufacturer says they patterned the bumpers off a GT5 and not a narrow body car.
T.Solo, PLEASE, I REALLY would like to see pictures of the fit !!
Thanks
I figured I'd spark some interest and yes I will post pictures. My car is apart right now with the front end on jack stands so I can't move it. I'll get some close up pictures posted in the next couple of days.
I did buy them direct from the Harrington Group via ebay. They are made to order and it took about 2 months to get them. While fitting them I discovered that one of the rear mounting studs was postioned out too far which prohibited me from achieving the tight contoured fit. I contacted them and after sending photos of the issue and some discussion they sent and overnight call slip and rushed the bumper back for repair. I had it back in about a week. Great customer service!!!!
Steve
I'm happy with them. They stick out only very slightly and without comparing another car side by side they look correct. Again it did take a lot of fitting. I spent 2-4 hours each bumper with a mini grinder equiped with a sanding disc some blue masking tape and pencil. Mark and sand the high spots, mark again and sand again. Once happy with the fit I placed the rubber trim all the way around the fronts and over the top and edges of the rears.
Steve
The bumpers can be ordered polished or black. Clearly mine are polished. They arrived with a mirror finish. The rubber trim was sourced from Tara at Hall's Pantera. She had it in bulk and I asked her to sell it to me by the foot rather than pre cut as on her website. That way I could do the complete wrap around the bumbers as I wanted to.
Steve
