My headlights are binding in their travel up and down causing the motor to overheat and wires at the limit switch to get hot. I have replaced the gear with a bronze one several years ago. I was wondering if there is any way to get the shafts out of the bar that connects the 2 lights. The shop manual shows the shafts with bushings but doesn'y say how to remove them.
thanks
Gary
Not to my knowlege. The parts are brazed in place after being assembled into the Pantera body. Typically, any binding is due to body twist from accidents, huge sticky front tires & vigorous driving etc. The headlight buckets bolt onto the 'lever' as you call them. Try taking the buckets out and running the lights with only the attach points to see exactly where the binding occurrs. I've also seen a bent sector gear (the big semicircular one) in one car that had had major front-end damage. We straigtened the sheet-steel gear with selective prying and pounding, but it takes a good eye to determine true straighness.
Not to my knowlege. The parts are brazed in place after being assembled into the Pantera body. Typically, any binding is due to body twist from accidents, huge sticky front tires & vigorous driving etc. The headlight buckets bolt onto the 'lever' as you call them. Try taking the buckets out and running the lights with only the attach points to see exactly where the binding occurrs. I've also seen a bent sector gear (the big semicircular one) in one car that had had major front-end damage. We straigtened the sheet-steel gear with selective prying and pounding, but it takes a good eye to determine true straighness. On my '72, switch overheating was due to a collapsed insulator at the base of the motor. This allowed the motor ground to 'leak' to the gear frame, causing blown fuses etc. I discarded the cute little bakelite insulator, connected the wires as before and tie-wrapped the ground wire away from all metal. After several years, it still works fine. Motor speed is faster, too.
