Originally posted by larryw:
Ignition: If one had the inclination to run the wire would it be better to get the power for this circuit at the ammeter rather than the battery cable? I ask because I have spare wires running from the ammeter area to the starter relay area. They were added by a prior owner for what I don't know, it's gone now. But they're there, 12 or 14 guage,neatly taped over and folded away.
Better? No, but go ahead and use the wires so long as they're in good shape.
It's
best to replace the ammeter with a voltmeter. Then where you pick up a high current connection becomes a moot point.
Headlights: Where would be the best place to mount these relays? Right footwell near the fusebox looks like it would put them closest to the wiring involved?
Sure that's one place where people mount them. Kinda makes for a awkward or tight installation. Behind the battery in the front boot is another common location.
Would it be worth the effort or even possible to use the headlight raising limit switch to keep the headlights off until the headlights are fully raised?
Consider this. I moved the red wire to unused terminal #7 of the headlight rocker switch. This raises the healights with the switch in the mid position, but the headlights remain off. Now I can momentarily rock the switch from mid position to the headlight on position, and back to the mid position; allowing me to flash my lights at slower traffic. This is a very simple 5 minute modification.
Fans: Where in the harness roughly is the Black/Pink junction you've tapped into with the 10 guage blue wire? Is it a soldered or mechanical connection?
There are several options. Poke your head under the dash.
Again, it's best to replace the ammeter with a voltmeter. Then the place where you pick up a current source is a moot point.
Theoretically you want all the electrical loads to be downstream of the ammeter, so it accurately displays a charge or discharge condition. But as we install higher current ignitions, higher current headlights, higher current cooling fans, we risk creating a condition where there is too much current passing through the ammeter with a resulting melt-down or fire. It has happened.
Mike Daley's web site,
The Pantera Place, has a section regarding these modifications that will give you ideas too. Go to his technical section.
cowboy from hell
