I purchased a HEI distributor that's the style with the coil in top is much taller and wider for my Pantera, The unilight Mallory is much small.
A friend recommended that I install new distributor.
quote:Originally posted by pantera74Bills6976:
look like it mite fit.
but I may have a bigger problem the drive pin was broken and I only found part of it a bout 3/4 the other part is some place in motor .
I looked for it with mirror but don't see any thing.
Is this a big problem or would it have fallen in to oil pan.
quote:Originally posted by larryw:
This is how a Duraspark fits in a late car.
Originally posted by 4V & Proud:
... can the MSD connector just be re-pinned ...
The MSD is taller but fits fine but now cant get motor to run . The motor cranks back fire a little but will not run. The distributor was put back in the same spot as old one. The old one was remove with distributor facing number one wire; check coil with timing light it is working . check voltage to coil it is good checked top dead center . five or six times check wires for times . pulled plug sparking but looks weak.
OK found the problem the harmonic balance came loose. replacing it with new one what a pain in the ass. New problem two blue wires run to the negative side of coil. the one with black stripe looks like it goes to the tac where does the other one go
Do I still need this wire to be aluminum . I replaced it with a heavy copper wire. Do I need to put a resistor on coil. A friend said even with a new Mallory supper spark coil you need a resistor.
