My new manifold is 4 inches higher then the old one, for those of you that also made the transition, I have a question.. The throttle cable appears to be long enough to reach. How or what did you use to connect the cable to the manifold? I have a mounting bracket to extend the "holder clip" to hold the cable but it’s not long enough. I’ve started to make an extension for it. Any thoughts? A picture would be great.
