I'm looking at my front end and do not see any adjustment for caster/camber toe, etc...
It appears the toe may be adjusted by using the steering rack connection, but...
quote:Originally posted by edmguru:
Hey Doug, as a matter of fact I do have power steering. You are correct, I checked the alighnment sheet from getting mine done and the toe in is 1/8 th.
quote:Originally posted by comp2:quote:Originally posted by edmguru:
How do you like the power steering? I got a power steering unit for mine which comes with an electric pump. I plan on re-building much of the suspension with many changes. I am not going to build the a-arms and uprights till I get some rims. There are too many factors I am working on and I want to get everything from the AI angle, scrub, anti dive etc just the way I want it.
Gary
The rack is a modified rack used for MGB conversion. It is basically a small car rack a vendor in the UK put's together.
The middle rack is the Pantera rack and the black rack is an MGB rack.
I chose it for a couple reasons. First many have said that many racks are overkill for the Pantera. Since this is for a smaller car I figured why not.
As luck would have it the ratios are very very close to the Pantera with another 1/2" travel.
It will require modification. I am not sure how well it would do withought getting into it as deep as I am. It will mount better from the frame rails then the power steering box. None of this is a problem for me as I am basically starting from scratch in some ways.
I can see where people would drop in racks and not be happy with them. There are many critical components. This rack is 3" too short so it will have to be lengthened. BUT...The Pantera geopmetry is not ideal either as the pivot points in the rack are not inline with the pivot points in the suspension. In fact I think the traditional bump steer fix; albeit the best solution for the car, actually creates other problems.
It is a little more then I can explain here but if I get all the geometry the way I want it I hope to have a totally different animal. If not, I will have gained some knowledge!
Sufice to say there is nothing simple about it.
I like the electric pump, but the mid 80's Chevette rack is a lot close to the Pantera in size and lock to lock. Ratio is almost the same and you only need to lengthen the tie rods about 1.5" per side.
The unit shown doesn't show a controller for variable boost, is that available?
quote:Originally posted by jeff6559:
There has been a thread about power steering on the POCA email forum and according to Mike Drew there is a guy in Europe who has a BMW power steering unit that works very well. SOBill Taylor has been doing some research as well. The Dallas person that Ghostridr mentioned (Nick S) has shipped the S2000 rack off to Dennis Quella to look at and so far, nothing has been done beyond that.
