Rick,
According to my blue owner's manual, page 65, the jacking points for changing a tire are just behind the front wheels and below the point where the doors and rear quarter panels meet. That makes for two jacking points on each side of the car. The jacking points are identified by a hole about 3/4 to 1 inch in diameter. Apparently the original jack had a pin to fit into these holes. In reality, I don't think I have ever used the rear point, but I do use the the ones up front. I put a 2x4 or 1x4, whatever will fit, between my floor jack and chassis to spread the load and protect the chassis. Since I have two floor jacks, I put one on each side of the car to jack up the front end. To jack up the rear of the car, I place my floor jack under the cross brace to which the rear sway bar attaches, this makes for a single jacking point at the rear/center of the car. I believe some people use a block of wood to protect the cross brace, I do not as mine was all buggered up when I got the car. Don't forget to leave the car in gear, set the emergency brake , chock the wheels, use adequate jack stands do the work on level ground, you know, all that good safety stuff. I hope this helps,
Art
Originally posted by PanteraHunter:
Being a newbie-type owner and before I do sometring completely stupid, would anyone be so kind as to point me to where I might find some documentation on the jacking points for a 1972 Pantera?
Thanks In Advance For All Of Your Help!!!!!
Rick
