What do you thing of a LT-4 conversion in a GT5-S 650/650 supercharged motor ???
Thanks, Wayne
#9437
quote:I think a Chevrolet engine in a Ford product is sacrilege.
A Ford crate motor can provide more than enough HP, if you stick with a Cleveland or Windsor platform it doesn't involve new-territory problem-solving and fabrication, and will raise far fewer eyebrows than a Chevy engine.
That said, on as rare a beast as a GT5S (only valid if yours is genuine and not a clone) I would advise against ANY engine swap.
quote:Originally posted by ZR1 Pantera:
Heard it all before from the same people.
The value of my car if through the roof because it is exactly how I like it and it is never going to be for sale. A win win for me!!!!!!
quote:Gee dude, chill will ya?
quote:Have you done any videos of your Pantera on the Quarter or around a track? Would be great to see the LS in action.
quote:Originally posted by wpl:
What about all of you who have non original engines ie... dart blocks, aluminum and so on
Do you really think a modern powerplant will devalue our cars???
Remember, the clevelend is no more than a truck motor!!!!! and very expensive to rebuild to modern standard hp
coments???
Wayne
quote:Originally posted by P-MAXIMUS:
Well yes, you can build a big high power Cleveland. I know I built mine. My GT5-S is a 1988 car. It has a solid roller, CHI heads,a hand made rev-kit. Also it has sequential fuel injection, 398CID. It can turn 8000 rpm but I limit it to 7600. Cost for such an engine capable of that with the best parts and you will spend at least 18000.00 or better. But, that being said sure build an iron block, carbureted Cleveland with still old technology, and still try to bring it up to date with the best parts. You still have old tech. And the price you quote of $15,625 no one will pay that. As that is retail.
Try to build a Aluminum Cleveland, weather it be a Fontana or Dart, World products
you will spend 3-4000.00 just on the block. The LT4 has Direct Injection, no distributor gear to fail. All aluminum block and heads, supercharged with 650 Torque @ 4400 rpm, 650HP@6400. And in a smaller, lighter package. And running a ECU to do the timing, you can't get a distributor to control timing as that can.
So as tech gets better even lighter and more powerful engines will come out. If we can put that in our Pantera's why not?
Thanks, James
quote:Originally posted by George P:
The OP (Wayne) wanted to know what we thought of an LT4 installation in his GT5-S. Lets not get off of that subject. Please focus on Wayne's original inquiry.
Thank You
quote:Originally posted by PanteraDoug:
Define "prudent"?
As 'Satan' is thrown into the pit he remarks, "you have no dominion over me". I didn't write the scenario but I've known some people that maybe...fit?
quote:Originally posted by 1973 Pantera:quote:Originally posted by PanteraDoug:
Define "prudent"?
The Merriam-Webster Dictionary defines Prudent as "having or showing careful good judgment".
quote:Originally posted by GTPowered:
While I would think the largest resale audience would be if you leave it with a Ford small block in it, there is no guarantee that it would be worth more money than one with a Chevy motor. It is your car, and your decision.
If this blog is correct, the highest selling price for a Ford era Pantera was paid for one that had a Chevy LS engine in it.
http://ringbrothers.com/blog/BarrettJackson2015/
On a technical note, I discussed with both Les Gray and Roy Butfoy about running supercharged horsepower in the 600-650 range thru the ZF and neither were too concerned. Les said the most likely failure would be in the higher gear. I cannot remember if he said 4th or 5th gear. Drag racing and speed shifting has broken ZFs in the past.
