This was the only post i found on the subject:
https://pantera.infopop.cc/top...539#1598208420767539
How does one even get to the rear wheel bearings?
Message_1666551148198
20221023_174126
This is as far as I got.  I can't get the perimeter bolts (near the rotors) to budge.  Even tried an impact wrench...  Does anyone have any advice on getting this assemblage apart?  Once I DO get them apart, has it been as difficult of a job as described in the above link?
Thanks in advance.
MH
Images (2)
  • Message_1666551148198
  • 20221023_174126
@rocky posted:
Just curious…. Have the lower parts of those uprights been damaged, and welded back up?  It looks like there’s only 1/2 a “DeTomaso” on the front there….
Cant help on the disassemble, though, sorry….
Good question...  I noticed that as well, but didn't check the other side and assumed it was "normal"...   I'll check the other side tomorrow...   This is what happens when we assume...
MH
sorry i meant to say " note the specific order the parts come out and ensure they go back the same"IMG_2512.  Mine had a spacer missing and it cost an axle. I took out the other side and realised one space was missing. I now have an extra spacer on the shelf should anyone require one. IMG_1500
Images (2)
  • IMG_2512
  • IMG_1500
@denisc posted:
Is that first picture supposed to be in two pieces?  or is that what you prefer to as costing an axle? (Meaning it broke apart)
MH
