My friend in the Appleton WI area needs a mechanic for his Pantera. It is a fairly minor problem with a ZF leak. The black side cover needs the gasket and seal replaced. The process is detailed in the link below. The transaxle is in the car but it is the side that is readily unbolted (the side with the castle nuts). Please let me know if you know someone in the area that can help. Thank you.
