Good Afternoon,
I installed new rubber motor mounts today and noticed they aren't perfectly aligned.
I'm 90% sure I have the bottom metal mounts on the correct sides, but I could be wrong.
The center bolt that runs thru the mounts isn't snugged up yet, but engine and frame mounts have been tightened.
Any ideas or is this an acceptable alignment?
Thanks,
John
Images (2)
  • mceclip0
  • mceclip1
...Yes! As a Machinist and a graduate of 'Technical Drafting', I can testify, the 'Assembly View' Drawing was drawn Incorrectly! In some instances, this may be defined as a 'Exploded View', Similar but Not the Same.
My Brother once worked for the NAVY/Government at Mare Island, California. Worked on Nuclear Submarines. Highly Trained, He Once told me, he discovered a '90 Degree' Bronze Valve, that Cost More than He Made in 5 Years...Was Installed Backwards!! When You Pay Peanuts...
MJ
