My sticker is still on my 74 air filter assembly but.... 20% of it is missing and it is barely legible. I don't know what the last three digits are. It is made of thick stock white paper fiber, yes paper, with thin black print. It reads D4AF-9600???. According to the Pantera master parts catalog the number 9600 is the part number for the entire air filter assembly. Part number 9601 is the air filter. Chuck
From that view it looks like there is an egr plate and valve sandwiched between the carb and the manifold.
The 2-1/2 inch round cylinder shape that you can see is the vacuum diaphram for it.
These cars were exempt from that type of equipment new but that doesn't make them exempt from passing emissions testing in some states. In my experience that is impossible without installing smog, but this must be a CA car.
My guess on the missing "sticker" would be that it is either the ford engineering number sticker or picking number sticker that was on the air cleaner for inventory purposes while at a Ford parts warehouse or factory assembly line. A paper sticker, rectangular, white with black lettering. Less durable than the orange dot on the valve cover. I doubt you would be able to find a replacement.
7260 is right with the numbers, the rest of the number is probably something like "AA" or "AB".
If you could clean off the glue I don't think any one would know there was a sticker there. cleaning the glue is eaier said than done.
ed..
