I have a Cleveland Q code engine and I want to get around 400 bhp out of it ……was producing a very asthmatic and very reluctant 280 bhp and my specilaist says that the engine has been fitted with what he believes to be the incorrect heads which would fully explain the poor experience of driving it so far.
A 4V Cleveland head will not be the culprit of HP limitation. Quite the contrary. You really need to figure out what you have first, but if it’s a Q-Code, that would be a low compression 4V version with cast dished pistons, open chamber 4V heads, and a hydraulic cam with the cam events retarded 4 degrees. This is commonly referred to as a smog engine here in the US as the changes above were done to make it emissions compliant for the era. It also emasculated the venerable beast. SAE net horsepower was listed at 266 for the 1972 version, and 246 for the 1973 version. The easiest thing to do is buy an indexable timing chain ($50-60 or so), put the cam events back to straight up and optimize the carb and ignition advance for this condition. This might get you back in the 300 BHP range with this approach. Problem is you’re only going to get so far with low compression ratio. What’s high-test in the UK these days? Don’t know what emissions testing you are subject to. Do you?
Originally posted by TCH911: …….The companies I am approaching are building very streetable V8 engines without boring and stroking so perhaps this is what they mean by 'maximums'. No fancy cams either!...............but I also don't want to end up shelling out for a brand new 180 degree manifold when ostensibly I don't think there is anything wrong with what I already have.
Well, if you want performance, you’re going to have to be willing to change something. I’d say the most basic bang for the buck (or pound sterling in your case) is a cam, carb (depending upon what you have), if you have dished pistons and open chamber heads, you need to get your compression up a bit. Easiest thing to do is put a set of 4V closed chamber heads on it. At this point you can basically choose the cam to achieve between 400-500 BHP, and any shop that is telling you that 400HP is undoable is probably someone you don’t want to do business with as the low end of this range can be done by accident, unless, as I previously said, unless this is an emissions constrained engine. The stock intakes manifold (if that is what you are referring to), is already a 180 degree configuration and are pretty good performers. Only real reason to replace the stock intake manifold in this power range is to save weight with an alloy version. If you are referring to your exhaust manifolds (extractors on your side of the Atlantic), you shouldn’t have a problem selecting compatible heads; there are many both OE and aftermarket from which to choose). You already have a big advantage here in horsepower over a stock Pantera exhaust system because the stock Pantera exhaust cans are known to relieve you of 30-50HP depending upon your state of tune.
You may have to lobby your government to relax its emission standards.
![Wink](/static/images/graemlins/icon_wink.gif)
Good luck,
Kelly
