First of the rear 19x13” rims assembled. 34 M8x40 Titanium taper head screws & flange nuts holding the three pieces together. (The 35th hole contains the valve stem). Still yet to machine up the alloy centre caps. It’s a very big wheel !!
This is the first time I have made three piece rims in aluminium, we do make steel rims for our offroad buggies here at Edge & the occasional beadlock rim. I did spend a lot of time on Solidworks playing with the design before the program went onto my friends CNC. The Pantera is in the middle of new panel work so it will be a while before it can be viewed fully clothed with wheels. Car is receiving new front & rear fenders, door skins, front hood & rocker boxes, as well as a complete new nose. It does take time.
