Can someone please confirm the FIM radiator petcock turns COUNTERclockwise to drain fluid. I want to make sure before accidentally ripping the thing off. thanks
If it is that tight, why don’t you just grab the proper sized hex wrench and remove the entire unit, and then do a bench restoration on the old one or replace with a fresh one?
