What are the respective THICKNESSES of the stock OEM front and rear Rotors? Also, what is the MINIMUM thickness that each can be cut to and still be usable?
usmcfred; Referencing the Pantera service manual: Rotor Thickness Front: New 51/64 inch, Refinished 43/64 inch Rear: New 47/64 inch, refinished 39/64 inch Runout: .004 to .006 inch
