You need to shield the oil filler port and the pcv from the oil splashing.
If you don't 1) the oil filler does not have the capability of 100% sealing and will leak oil 2) the pcv system is going to be flooded with oil.
As far as using the drip tabs with roller rockers, you can use them but you need to take sheet metal snips and trim them to length to make them fit.
Is it worth the effort? That I don't know BUT as one of my "friends" says, "Ford didn't bother with them for nothing?"
If you want the drip tabs then as far as I know no one has them separately as well as the oil fill shield.
You might look for a set of original Boss 302 valve covers that still have them installed?
Someone like Virginia Mustang may have repro Boss 302 covers. If not, you need to make the rounds of the Mustang parts suppliers here.
Go to www.saacforum.com and post a wanted add for the parts that you want.
There are several people there that I know have the parts that you want but they are not normally sellers.
