What filter to use on a 72?
I use a wix 51516xp. It's a little smaller diameter than what's typically used. For me, with the standard larger diameter filter, my headers all but touch the filter housing. I believe the larger diameter filter is 51515xp, but double check that number in the wix catalog if your interested in the larger filter.
Ditto for the Wix brand.
Remember, if it is an engine part you can find almost everything by telling the parts clerk you need -whatever- for a 1972 Mustang with a Cleveland engine.
NOT Windsor. 😉
Thanks
No problem man!
Works great. Summit Racing!
Warren
lf-tp2511 posted:Ditto for the Wix brand.
NOT Windsor. 😉
Cleveland and Windsor use the same Filter....
IPSCO billet oil filter.
