Thank you Panterplace,, I'm Looking at a used lift,,, Trying to make sure it will all fit. The roof is 8 foot,,, lift might not work, if it does make it,,,there will only be an inch or two,,kinda close..
t Ontario Motor Speedway at 2860 lbs.. So, take your pick. The SPORTS CAR GRAPHIC article shows a photo of the Pantera spec.- sheet typed on a HOTEL REAL-FIN letterhead in Modena Italy, which I think was owned by the 'capo' hisself; Allesandro ( See P. I. Newsletter # ? ), so maybe........... Source : PANTERA "GOLD PORTFOLIO" by Brooklands Books. Regards, tai.
Sorry all. The front part of my posting got swallowed up into the Electronic Ether on the way from me to you'all, it seems. It went something like this : MOTOR TREND May '73: L 'long-nose': 176.0 inch / 71.3. weight 3580lbs. MOTOR TREND, Karl Ludviksen April '70: Non-L: 167.0 in. / 67.0. weight 2860lbs. SPORTS CAR GRAPHIC May '70 : 167.0 / 67.0. weight 2860lbs. ROAD & TRACK, Pete Coltrin May '70 : 167.0 / 67.0. weight 2860bs. WORLD CAR GUIDE, June '70 : 167.0 /67.0. wt. 2860lbs. POPULAR IMPORTED CARS, Alex Wolordy Sept '70 : Same as above. CAR & DRIVER, Aug '71: Same,except :3123lbs. ROAD & TRACK, Sept '71 : " " : 3155lbs. - Why the difference in widths tho ? Cherrs,tai.
