If anyone can be bothered, could you please measure the track width of your Pantera from outside rear wheel to other outside rear wheel?
If possible, anyone with a 'real' GT-4 car (thats pushing my luck haha!) or clone GT-4 like mine (.... would be good to compare GT-5 and narrow body cars too)
Due to my wheel offset measurement stuff-up when i was getting my car built at the time and not fixing the flares properly to the car first before measuring, i ended up with 'too deep a dish' therefore my car is wider than should be:
My measurements:
Rear wheels from outside edge to outside edge: 2025mm or 6'8" (plus 1/2" to 3/4" approx extra each side for flare overhang)
Front Wheels from outside edge to outside edge: 1835mm or 6'
The dish in my rear wheels are about 9-3/4" to the outside which leaves about 5-1/4" on the inside (The 18"x14" inch rims are about 15" wide from outside lip to lip).
The dish is weighted too far on the outside and i always have in the back of my mind that there is too much cantilever force acting on the axles, i took it on the racetrack last weekend, and everything went well, but im not sure if i should get heavier duty axles if i continue to take it to track for a bit of fun??
Does any vendor make stronger axles than standard?
Thanks!
Laslo
Hi Laslo,
My car rear outside rubber to outside rubber measurement is 78.5 inches (i.e. 1993.9 mm). You've got me by more than a few millimeters mate........
I know of a guy that makes CV joints if you want to go that route. If you want to go the universal joint route I don't know much about that, but I'm getting CV's made by a guy named Ike from the Los Angeles area. He does really good work and here is the web link for the site:
Pantera Driveline & Suspension Parts
If you want his contact information I can dig that up if you wish.
Best of luck!
Mark
Sorry Laslo, my bad. Yes, Ike can get the CV axles that just replace the universal setup that hooks into the axles that go through the rear uprights, and he does make stronger axles, but I do not know if he makes them for the conventional setup or if you need to have his upgraded uprights?
Sorry for the confusion. Actually, sorry for me being confused.....
Mark
Laslo,
I can’t comment on the SACO performance units. I remember corresponding with Mark Greene on them some time ago. It looks like good stuff, uses a cartridge bearing assembly and readily available axle and flange combo (Porsche maybe) but not sure I understand whether those axles would be any less susceptible to your concern.
I’d recommend Mark William’s Enterprises if it is just a good Pantera axle is what you’re looking for. I’ve had them on my car for years and also in another set of uprights. The William’s units are made from 4340 forged axle blanks used in many of their other racing axles. It’s just hard to beat a good forging because the grain structure flows and aligns in the direction of stress in the radius where the axle transitions to the flange. This makes them much more durable with higher fatigue strength. Williams also have much experience in post heat treatment which is also critical. I know several other of the Pantera vendors have offered axles as well. I would caution about any of the billet axles. There are just few materials that will produce a better axle than forged 4340 at least within a practical price range. William’s aren’t typically the most accommodating folks because this stuff is just a novelty for them but if they don’t have a set on the shelf (and they usually don’t), it’s typically 3-6 week lead time. They aren’t the least expensive but the quality is always top notch and you know what you’re getting. Last I checked, they wanted $760 per pair for them.
http://www.markwilliams.com/
You’ll need to download the pdf catalogue and look on page 16.
Williams offers a Pantera CV conversion but it’s just stupid high priced, $4500. If you want to do a CV joint conversion, as far as I know, Williams are the only ones that make the companion flanges that have the 8-spline configuration for a Pantera axle and directly replace the Pantera U-joint flange on the rear upright assembly (as pictured below). They don’t list them in their catalogue but they are very proud of these things and last I checked they wanted circa $1000 per pair for them.
Williams also make the CV stub axles for the ZF side ($590/pair last I heard) but RBT had offered M1 CV flanges that were more economically priced. The Williams units do have a centering feature for the CV whereas the M1 units do not. You can source 930 CVs and axles from many places, sand buggy, etc and I suspect local to you.
I bought CV conversion parts with the William’s companion flanges from Dennis at Pantera Performance. He offered his kit’s for $2500. I bought his last set at a discount and he indicated he wasn’t going to do them anymore because there was just very little interest at the price.
If you just want to run CVs, for sure the most economical route is to buy a pair of flange adapters from IPSCO and source your own CVs and axles. Not sure if they are on his website but I think they were a couple hundred dollars. He’ll make them if you call him. They look like the one pictured below.
http://www.ipsco.org/
Back on the subject of Pantera axles, in my opinion the stock Pantera axles are actually pretty good pieces and the stories about the breakage from use of big wheels is a bit over blown. There certainly have been documented cases of axle sheer but I would contend many of them are actually caused by cars that had stock ball bearings in the upright whose stock axles were damaged by improper fit of the ball bearing race. There’s no doubt this was a common problem from the factory. Improper (loose) shrink fit of the inner race on the axle caused slippage and thus fretting and stress risers in/near the critically stressed location. The bearing failure is accelerated by big tired cars and damaged bearing rapidly abrade the axles on poorly fit units. Before aftermarket axles were available most guys plated or metal sputtered then polished the diameter of the stock axles back a diameter for proper shrink fit of the stock bearing, though most owners of big tired cars have long since gone to tapered roller bearing conversion.
Best,
Kelly
Uh, yea, what he said......
Excellent write up. I do remember the Williams axles and yes, they are legit. I would also say that Williams' CV setup is a bit on the pricey side -- there are better mousetraps out there if one wants to go that route -- but yes, I totally agree with Kelly on the Williams axles -- they are the way to go on a conventional Pantera setup.
Mark
Laslo, my Pantera is 2000mm wide.
Running 345 tyres.
I also have 930 Porsche CV’s fitted & using race buggy axles.
You can buy race buggy axles to suit 930 CV’s of all different lengths.
Go here to the Pantera Australia Forum:
http://panteraaustralia.com/fo.../124.html?1331339578
I have listed here the drawings & details of the CV conversion parts that I designed, same as what I’m running on my car.
I also upgraded my uprights to 40mm ID x 80mm OD taper roller bearings.
But that is a hell of a lot of work.
Regards,
Tony.
  • CV_PARTS_copy
Stock halfshafts are more than strong enough for almost any modified Pantera engine, but stock outer stub-axles DO break under race conditions. Gumball tires will sometimes do it in a 3-hr enduro event while at least a few have broken with hard driving on big sticky street tires. Short-duration autocrosses will not. OEM '71-'76 OEM stub axles were made of a rather soft mild steel, and many were undersized from the factory so the ball bearing races fit loosely. Resizing the axles by various methods fixes the bearing-fit problem but not the weak metallurgy. New stub axles of EN-300 steel from Wilkinson or billet 4130-axles from Hall (and others) fixes both problems, at a slight cost in heavier unsprung weight (these stub-axles are no longer hollow). FWIW, stub axle breakage always occurs at the large chamfer between the horizontal axle shaft and the vertical wheel flange. I've seen OEM stub axles worn so badly under the outer ball bearing that there was a 1/2" wide x 0.180" deep 'wagon track' under the bearing race, and the axle had not (yet) broken.
Std disclaimer: I personally run welded and resized OEM stub axles and lighter weight Spicer aftermarket halfshafts. One stub-axle mounts std. ball bearings while the other runs my own tapered roller conversion for a long-term comparison. Since July of '98 (a 14-yr period and counting), there has been no detectable performance difference from either bearing type under any driving conditions. Theoretically, the roller bearing will run a bit hotter and soak up a little more power but in a street car, no one can tell them apart.
I've never tried CV joint halfshafts in a Pantera, but it seems there's always a weak spot in any design and with these, it's the rubber boots that MUST be intact to hold vital grease inside the joint. Indexing the axles and even denting the pipes to increase boot clearance near the hot exhaust pipes seems crucial.
Originally posted by Bosswrench: Stock halfshafts are more than strong enough for almost any modified Pantera engine,
Agreed. It’s an old subject but another example of exaggeration about them being weak and needing replacement. The source of the problem was availability and quality u-joints that gave rise to aftermarket substitutions, usually as a more economical alternative to staying with stockers. It later mutated into a strength myth.
Yah, but what doesn’t?
Mild steel? I must ask the source of that info? The reason I ask, many years ago when Mark was doing the development work that led to the Williams axles, the problem induced by bearing fit was common enough that they were plating/sputtering original axles because they had tested the hardness and although I forget the figures, they found them to be in hardness regions way North of any mild steel, more in keeping with the typical age hardenable alloys one would expect to find in forged axles, thus, they used diameter build methods less likely to disturb the original metallurgy. For cost reasons alone, it’s almost a certainty that the original axles were forged. On the materials metallurgy, the splines and threads sure don’t seem to act like mild steel, but this has piqued my curiosity. I have a stock axle. I’ll have to see how hard of a material I need before I can move the surface.
The Williams units have always been available drilled. It’s just an upcharge.
I certainly don’t doubt such failures have occurred but do question whether it is strength of the stock axle or the mechanism I mentioned in the post above that causes the failure. Out of curiosity, there were factory and privateer cars campaigned for a long time, and as far as I know, long before any aftermarket axle offering. Are you suggesting these were only able to avoid axle failure by being fitted with special non-stock axles?
Agreed
One tapered roller conversion and one stocker? A 14 yr and ongoing test? You are dedicated to your trade!
It’s been discussed in other threads but I’ll repeat it here for completeness of the thread. There’s no doubt that CVs are a superior joint to U-joint. As the name suggests, they are constant velocity and U-joints are not. They will more efficiently transmit power to the ground than a u-joint. How much of the 20% or so that is lost from flywheel to the ground? Dunno. It would just be speculation. The benefit is somewhat diminished on a Pantera because the travel is limited and the initial position does not impart much misalignment. It’s a much bigger deal on buggies and off road vehicles with mucho suspension travel.
While the boots do prevent some loss of lube, it’s not like they are holding the grease in the joint. They are essential in keeping out debris which is critical for their longevity. I’d agree the boots are not very durable. Since Panteras have limited travel, they don’t need much of a boot. If you look close in the pictures in my post above, you can see I have the shorty boots on mine and they are much more durable and shielded from heat. With 180s heat exposure is a moot point.
Other than some subtle gains in power transmission efficiency, the CV assemblies can be made to be lighter in overall and unsprung weight compared to stockers. The CV joints in the side-by-side picture above have had the housings cut down to lighten them. This is a common mod done my many shops. You can gun drill the shafts as well. It all comes at a cost, but those last few pounds always do. They can also potentially provide more exhaust clearance and with high strength cages and treatment of the star/knuckle and housing, handle considerable more power. The ones being used in buggies, sand rails, and drag racing survive incredible amounts of abuse. Is it needed? IMO, definitely superior driveline but hard to say it's the best value for money.
Best,
Kelly
