You're right- I went right by Jim's photo! The reason I mentioned it is that all those all-steel links and pivots are usually worn badly (mine were anyway) and that puts slop into the clutch motion. Panteras cannot afford ANY slop in the clutch motion- we don't have enough as it is! So if you have the effort-reduction thing, lube it as best you can- likely it hasn't seen oil or grease since Modena!
