My granddad and I are working on 1971 model and are trying to locate the fuel filter. unfortunately the manual doesn't have a picture of the engine taken apart. can anybody help
> My granddad and I are working on 1971 model and are trying to locate > the fuel filter. unfortunately the manual doesn't have a picture of > the engine taken apart. can anybody help
On the Motorcraft 4300 carb, the filter screws into the carb fuel inlet. If you need a picture, I can take one this weekend. NAPA should be able to get you the proper filter. Also, many people splice a filter between the mechanical fuel pump and the carb inlet, particularly when they use a Holley carb (which have sintered bronze filters in the inlets).
Dave, The pic of mine was before I replaced it and the manifold. The OEM has been relegated to the parts bin for? It was well past its prime and I could never get it to run very well.
We are all assuming he still has the 4300 on the car.
