I think any turner can make a ring if they are told the dimensions. Maybe Marlin Jack can point them out?
I made one myself in bronze which I adjusted to the diameter of the input shaft after having ground and polished it to eliminate traces of corrosion and soaked it in hot oil.
I made it wide enough so that it could accommodate a sealing ring.
Unfortunately I did not note the dimensions, I did not think it would be useful but it is easy to measure the external diameter on an old ring or an old bearing and an internal diameter larger than the input shaft by 0.05 mm will work fine.
Images (3)
  • mceclip0
  • mceclip1
  • mceclip2
Sorry, I didn't mean to "offend" you at all but:
- You are not the only machinist in the world who knows how to work with precision
- These bearings, or rings, or bushings whatever you want to call them, are not high-tech elements, you shouldn't exaggerate either.
- Extreme precision is useless, this ring does not undergo any effort, it just serves as a guide to prevent the input shaft from vibrating and rubbing against the differential housing, no need to look for the micrometer for that .
We all like you well here and recognize your great skills but frankly, your bad moods attacks are sometimes annoying.
No hard feelings?
@marlinjack posted:
...I Love That! "Precision is Useless"! You're Arrogant!
I'm trying to calm things down and you insult me!
You say that I am arrogant because you know that while you were in VietNam, I was studying engineering in one of the best French engineering schools and I learned there that it is useless to be more precise than necessary.
I also learned that when the coefficient of expansion of the material of the internal part (between 14.5 and 17.5 for bronze) is higher than that of the external part (11 for steel) the internal part cannot come out all alone because of the heat, on the contrary.
This isn't the first time you've made mistakes and you're upset because I see them. I do it too, but it doesn't offend me if it's pointed out to me.
For me the discussion is closed, it no longer interests me.
@marlinjack posted:
The Crackshaft Bearing POCKET can get up to 300F-400F Degrees, I'am guessing here. The Steel Expands More than the Bronze. If One has followed Instructions and Cleaned out the Pocket "But don't Make it Larger!", or there has been corrosion, that was cleared out...the I.D. of the pocket will Be Larger than the 'Nominal' dimension of ONLY 1.3750"!!
Fake:
chrome-extension://efaidnbmnnnibpcajpcglclefindmkaj/https://psec.uchicago.edu/thermal_coefficients/cte_metals_05517-90143.pdf
Unless the University of Chicago is wrong
I am not and never have been a machining professional and I am sure you are much better than me at a lathe or a milling machine, but on the other hand, yes I have learned to define the right level of to be precise, this is the work of the engineers and the machinists only carry out what the engineers have determined.
No, I never served, I was lucky not to be one of the young people that our governments needlessly sacrificed, since USA, like France before you, lost the war against communism. But I respect veterans.
  • mceclip0
Well, I hope that pissing contest is over.
Back to what this forum is about, people helping people.
So for the guys like me that are not Master mechanics, master welders, electricians, Machinist etc… Just average Shadetree mechanics that understand the limits of our knowledge and abilities that know when to seek help.
I hope guys continue to ask questions here and not be afraid that their question might sound stupid. Always better to ask a stupid question than make a stupid mistake. I’ve posted lots of questions and the brain trust here has always been very helpful without fail.  For that I offer my deepest appreciation and thanks.
So, here’s my question, has anyone found out if any of the Pantera vendors sell a pilot bushing?
Ok, Back to the original post.  Can anyone recommend a pilot bushing that we can buy today that would be the best we can buy today for our application in a Pantera?  That is what I am looking for.  Please help!
@marlinjack - Again since you do not make these anymore, that is why I am asking. the question.  If you were still making them, I would buy one of yours.  I just found one from Mcleod that I thought would be a good one that I could buy today.  Any recommendations would be appreciated.
@panterapatt - Good idea.  I will call the vendors to see what they recommend.  I will also call Greg at Full Throttle Panteras and see what he uses.
Again, any recommendations would be greatly appreciated.  Larry
Since Marlin is no longer making them,
I would look for a NOS Ford bushing. It is originally what was used in the Pantera. That is what I use in all of mine.
C8AZ-7600-A.
I don't see any for sale at the moment but they are out there and they do turn up. The Dorman will work but as with Marlin's caution, the alloy of the material is important because of the ZF non-tempered input nose.
As a result you want to know the alloy used. Dorman isn't specifying it. With the Ford, you don't need to.
I have not checked with the clutch companies but I wouldn't be surprised if they did not know the answer to that?
All the information that you need to know really is posted here in this thread. The cautions are here. The cautions are explained about the materials.
Looking at the bushings and bearings readily available no one is specifying magnetic or non-magnetic. You will need to ask that before you buy.
I do know that in addition to the oilite variations out there, there was also a solid bronze bushing at one time. It was also non-magnetic but contained no lubricants.
I personally would add that the pilot roller bearings in my experience are not what you want to use. They have no advantages and present some additional potential issues.
The simplest way to deal now with the controversy is to use an OEM Ford. You have to do your homework and actually search for one, like maybe call one of the Pantera parts vendors?  Sometimes it appears that all of "us" take too much for granted and expect everything to just fall in out lap like ordering a Big Mac and having it delivered?
There is a D0AZ-7600-A Ford bushing that is also out there. It superseded the C8. The way Ford Service Parts works, it should also be essentially the same but I don't know that as a fact and what is different if anything, about it?
In reality, this isn't all that complicated but there are a bunch of novices here that need some very simple things explained to them. Some of us are trying.
I'm not sure if they are exactly the same? Ford's normal procedure is to update the parts.
Usually this just means that the engineering criteria is the same or improved but they can look different then the "original Production line" part.
So for things that are important to "restorers" parts that are exposed in displaying the car in a show competition, that has always been an issue and why there are some very expensive parts out there for sale.
In the case of this bushing, it is strictly the function that is the consideration.
I thought you made a typo on the price?
Someone who has done a lot of Pantera engine/tramsaxle work like Ron Mccall would be the guy to ask about this though. Wilkinson, although helpful, is not a mechanic that might be aware of special issues with the ZF application? It would take time and mileage on the part to show a problem. How many miles? Who knows for sure? Best to be safe,
Just to expand the knowledge base a little…
The first picture below is the page from the Orange (‘71 - ‘74) Pantera Parts Book.  As Bosswrench called out in another thread…. Both the bearing 7600-A, and the bushing (7600-B) are listed (I’m using Ford’s terminology here).
The second picture is a Ford Bushing that came out of Ken Daniel’s car.
I can’t say if the part number on the box (even though it has the 7600-A designation) applies to the bushing…. Just that it was in the box.
QUICK FOLLOW UP:  The D8TZ is from a different (and later application)…  see third picture…
KD was a hot-roddler, built many high-performance engines, and ran his car at Silver State, so that Ford box might have been from a bearing he installed, and then he just put the used bushing in it.
IMG_4332IMG_4330
IMG_4333
Images (3)
  • IMG_4332
  • IMG_4330
  • IMG_4333
There was discussion of bushing v. bearing a long time ago. It might have been in the early '80s when Ford reintroduced the Mustang GT? I do not remember the date exactly or the circumstances.
I do remember trying a roller bearing  when I did a clutch in my 82 Van. It did not last long but I noticed no damage to the nose of the transmission.
I see no advantage to a roller bearing. Bearings fail. Bushings do not. The simpler solution is always better.
I have no way of proving, one way or the other, if the input shaft of the ZF is hardened or not. I do find it difficult to believe that it would be just plain tool steel? The simple test that I was taught was that a file will not "cut" a hardened part.
There are degrees of hardness and that is reflected in the Brinnel test. That is commonly done on crankshafts and you will see evidence of it with a dimple in a non structural area of the crank. The deeper the dimple, the softer the crank.
Cleveland cranks in particular were tested for hardness. The harder ones were used in the higher performance applications since they are all nodular iron. Theoretically, the Boss 351 got the hardest.
To what degree the ZF transmission input shafts are hardened, I don't know. I never came across that data or a discussion of it. I do know that Ford was not impressed with the ZF in general and had many criticisms.
It would make sense since the shaft is going to be subject to twisting, bending, tensile and shear loadings and hardening it improves the strength across the board.
The pictures I am seeing of the ZF mainshaft and the transmission disassembled are looking to me like I see the blackening from the hardening process.
I can't argue one way or the other if it is hardened or is not but I accept the caution to use a low iron, high copper bushing.
Anyone with one out of the car can do the file test on the nose of the input shaft though. That will answer the question.
Yes, the D8TZ-7600-A looks like a caged needle bearing in an adapter housing.
Certainly is different than the bronze one that was in the box…. But the parts book shows both, as Jack mentioned in another thread…
(I’m pretty confident now that box isn’t the one that goes with the bushing…)
IMG_4335
  • IMG_4335
