Jerry from PIM asked me to call him. I didn’t have time today but should be able to tomorrow.
LeMans850i, I appreciate the input. The engine made about 5” vacuum or less until I increased timing and put the carb back to factory specs . And it ran better. It ran even better at about 13:1 AF when I leaned the jets. Are you saying that is too lean for that engine at near full rpm under load? ( my test conditions ).
I installed the PCV to the carb flange. Prior to that both breathers (no pcv) were plumbed to the air cleaner, which was wet with oil and the hoses were soaked with oil ( leaked all over when disconnected ). Now there is no oil residue in the air cleaner and oddly enough not in the PCV hose either. It’s easily reversible and I don’t think that it’s causing a vacuum leak. Vacuum was low before I ever made that mod. I’m open to understanding this better and can easily reverse it back to two breathers plumbed to the air cleaner.
One of the reasons I’d like the cam specs is to better understand the maximum rpm. The owner wants to spin it to 7,000 which I have STRONGLY ADVISED AGAINST. The MSD currently has a 6,000 rpm pill in it. Your comments lead me to believe it should stay at 6,000. I find that a little concerning only because engines I’ve built in the past ( Cleveland’s ) could spin to 6,500 easily before valve float and I usually rpm limited them ( right or wrong ) to 6,300.
in the end, you’re recommending putting everything back to the way it came. That is easy enough to do. And then we can evaluate it and start again. I won’t see the car again for two weeks but I’ll be prepared to reverse all the changes.
FWIW, I don’t think the rockers were changed. There was an idea that maybe the rocker ratio could be changed but I didn’t want to ho down that road. I want to know cam specs and the associated parts to better understand max rpm.
What is your opinion of airflow through the dogbone air cleaner? I’ve been given data that shows it can rob horsepower on a 427 stroked Windsor. It can’t get enough air which could explain the wet air cleaner or it could have been blow by but it doesn’t seem to exhibit blow by. We were planning on replacing the air cleaner with something that flowed more. Just curious your opinion on that part as well.
Thank you for your comments,
Asa Jay
Hammer is a 6k redline engine.. For my car I’m looking to do something more rev friendly.. 363 - short stroke big bore… now that would do 7k if properly build to do so!
4.030 bore and 4.170 stroke doesn’t sound like a rever to me… at least not as a lasting and reliable machine (unless you dump ungodly amount of money into it ) This engine is build for torque and to last… bringing it up to 6k is almost pointless, well, it is pointless! Torque comes down around 5k so shifting at 5k would get you around where the Torque is coming in hard again! It’s just the wrong engine for what’s asked for .. in my unprofessional opinion! (and you create more heat at higher rpm)
Its like you asking a fat guy to sprint … he might do it a few times, He won’t be good at it, and he will be dead after a while!
but if you take the same guy for a tug-of-war… Different story…
The second problem you may encounter is that this engine has a hydraulic roller cam and I don’t think those do not like to rev that high.. So you would have to convert to solid lifters! -The squeeze is not worth the juice 🥤Also, as you said, the valves… those huge intake valves are quite heavy and to persuade them to close in time….. that would take some springs (or titanium valves) !! And the hydraulic roller lifters Will complain!
just put breather caps on the valve covers and plug the port on the carburetor.. That’s what I’m doing! You definitely know when you have excessive blow by… Lol
if you want to do something good with the air filter… Get cold air into the intake!! That helps more than anything else! Right now it’s just sucks the hot air in! But to achieve that you have to build something… There’s nothing on the market that does the job!
There are many dog bone air cleaners on the market, but they’re not all the same… Be aware! Whatever you build the distance between carburetor and the upper deck of the air filter housing should be tall as possible, which creates the next problem on the Pantera because you can’t see out the rear window anymore.. and hopefully you have a high-quality balancer on the engine… and I’m not sure what the water pump will do…
I would make the engine run nicely, put the AFR gauge on the shelf, drive the car for a while and then read the spark plugs….. this will tell you a lot more! Not all cylinders get the same AF filling necessarily (it’s carbureted !!!) and you want to know if you have a lean cylinder.. and that’s the one you want to keep happy!
As I said, this is just my unprofessional opinion….🤪
(Sorry for rambling on so long)
