yep! put some stones inside... the smaller the better stay away from sand,(unless you have access to an air compressor then put a little sand in it and blow the heck out of it... mini sandblaster effect) and make a video of you doing the cocktail shaker moves Smiler
As for POR15 works great on outside parts, my floor-pans are POR15 done, I would check the ratings for constantly wet hot areas.
Muriatic acid sounds like the nuclear option. I have cleaned rusted fuel tanks with straight vinagar. In any case a good rinse and baking soda to stop the action.
I have used a product called "Red Coat" to seal fuel tanks. It is like pancake syrup. You have to rotate the part to coat all sides. Cures over night. O'reilly auto parts has it behind the counter , $25 a quart.
I have no idea how Red Coat stands up to hot water but it is an idea.
I do love POR-15 products and they cure from moisture so would not pour any left overs back in the can.
Dear RRS1,
I took the liberty to call POR15 technical line. "Keith" claims that as long as you properly follow the protocol to degrease, prep the surface and apply POR15 that it will be fine. He alleges that this has been done before without problems. I specifically asked if using POR15 in a application where it is immersed in water and coolant 24/7 would be a problem. "Keith" claims: "no problem". Somehow, I am not completely convinced.
Chuck Engles
