I bought a Powermaster 100amp single wire alternator from Summit. Used them succesfully in the past on my 302s but this is the first time on the Pantera.
I want to get rid of the external volt regulator but will I now not be able to use the gen warning light on the Pantera. The powermaster has an outlet for the gen warning light but in the instruction sheet it says not suitable for cars fitted with factory amp guages, see below from instruction sheet.
Optionally this indicator light function can be used on a Powermaster alternator in vehicles with a
factory voltmeter by removing the black rubber cover on the side of the alternator and connecting the
indicator light circuit to the #1 terminal of the Powermaster alternator.
Vehicles with a factory
ammeter cannot use this function
Does this apply to the Pantera wiring setup/amp guage etc, if so is there a way round it so I can use the gen warning light.
Cheers
Horace
