Originally posted by Anders Hellberg:
was it Holley 4777?
which intake can you check it?
have you paper that says DeTomaso part no on the intake?
Yes a Holley 4777-2 with no choke flap.
The intake had an aluminum tag, no piece of paper.
interesting K-621-JG is a 71 CJ Engine code Q Comp 8.6:1 according to TSB #4
I haven't seen an engine code tag before are there any more that have one?
does anyone have Detomaso code?
Detomaso code looks like this 608 AG, 613 J, and 621 JG. Maybe there are more
The only code I have manage to crack is.
Ford code K-613-J is De Tomaso code 613 J and it is a 351C 4V 71/72 M code
George mentions this tag number in one of his posts.
http://pantera.infopop.cc/eve/...0052674/m/2990043404
Originally posted by accobra:
That looks like the same intake on mine ... whick is odd because the car is a 1979 Euro GTS with what appears to be a 73 intake ?
Mats Gorski had a D3ZE-9426-AA intake on his Pantera -75 VIN 7434 and a 4777 Holley.
bdud have you a D3ZE-9426-AA intake also?
Anders don't you mean a D3ZE-942 5 -AA intake?
Mine is a D1ZE-9425-BB, certainly cast iron.
A couple of websites..
http://www.mercurycougar.net/f...dex.php/t-26876.html
http://www.mustangtek.com/FordIntake.html
yes of course D3ZE-9425-AA
The Europeans do not necessarily care for the aluminum intake manifolds since they cause issue with the carbs freezing up in weather below freezing. The iron manifolds work better for those conditions.
I'm surprised that the carb is changed but the intake is not.
Why the engine tag is still on there is a question. Certainly racing the car would have taken the engine out of warranty. Maybe it was left there just for future identification for replacement parts?
I know that even on the Shelby race cars, the stock "Shelby" engines were left there on the race cars for customers. This way if the new owner blew up an expensive race engine that he bought from Shelby, there would be no hard feelings over it.
Perhaps Detomaso worked the same way.
In the era, the stock 4v Cleveland was probably more than adequate for the Gp3 cars. Those would be raced in "club racing" and not the heavy duty racing were you had manufacturers competing against each other and wanted every available horsepower they could get out of the engines?
maybe it is "just" a tuned engine and not a GR3 engine... Confused
I spoke with a Swedish guy who competed with Pantera in the 80s - 90s and he is today high up in historic racing that DeTomaso came with an aluminum intake, but unfortunately he can't remember which intake it was. Frowner
I think also it was left there just for future identification for replacement parts.
There is no performance benefit to switching to the Ford aluminum intake manifold. It is just a weight savings thing.
which Ford aluminum intake manifold?
The aluminum tag is the Ford tag that identifies the engine. It is not a detomaso applied tag as far as I know.
I know it is a Ford plate, but DeTomaso also had engine data plates but I don't know how them looks like...
There are two versions. One with a square bore Holley pattern, the other is a spread bore pattern.
The spread bore was the Boss 351 manifold and the square bore was over the counter.
The aluminum dual plane manifold with Holley 4150 bolt pattern had either D1ZZ-9424-G or D1ZX-9425-DA casting numbers, was sold under part number D1ZZ-9424-G. It had two slots, and could accommodate an 850 cfm Holley. At least a few of the push-button Panteras were equipped with this manifold.
The D0AE-L iron manifold also had the Holley 4150 bolt pattern. Instead of two slots it had 4 holes which were so small in diameter that the manifold could not accommodate a carburetor larger than a 650 Holley without modification.
The spread bore aluminum manifold for Autolite 4300D carbs had a casting number of D1ZX-9425-CA. It was standard equipment on Boss 351 Mustangs, and is worth a mint $$$ to owners of those cars.
The spread bore iron manifolds, designed for the Autolite/Motorcraft 4300D carburetor had 4 holes, they had casting numbers beginning D1ZE, possibly D2ZE, and D3ZE. The primaries of the 4300D carburetor were the size of Holley 600 cfm carburetor butterflies, the secondaries were the size of Holley 1050 cfm Dominator butterflies. 300cfm (1/2 of 600) plus 525cfm (1/2 of 1050) equals 825 cfm. The carburetor was rated by Ford at 750 cfm. It has been my joke since 2001 that the spread bore 4300D carb was like a mullet hair cut ... business in the front and party in the back! Smiler
If a person wants to use an Autolite/Motorcraft 4300D (spread bore) carb, one of those D1ZE iron manifolds are almost a necessity. If you look at the carburetor mounting pad you'll notice the two small holes for the primary butterflies are in the middle of the manifold. The carburetor is off-set to the rear of the engine. This was done to improve part-throttle (cruising) performance at the expense of high performance operation. In addition to that alteration the D3ZE manifold also had a trench along the side of the carburetor mounting pad in order to supply exhaust gas to the EGR valve. Snake a chain through the D3ZE manifold and use it an anchor for your fishing boat ... that's about all it is good for.
It is the opinion of Pantera International that every 351C equipped with 4V heads is better-off with a Blue Thunder intake manifold (available in a "Pantera version") and a Demon Carburetors #1402020VE carburetor rather than the factory induction (including the De Tomaso single four barrel induction). However, there is a caveat to this recommendation; many applications will not realize any benefit unless:
(1) the engine is rebuilt to resolve any ring seal or valve seal problems
(2) the static compression is raised to approximately 10:1
(3) the ignition and carburetor are in good working order and tuned for the particular engine
(4) the camshaft and/or valve train are at least up to showroom 1971 351-CJ spec (but preferably upgraded beyond that spec)
Refer to sticky #3 in the engine forum for additional information.
-G
Every 1970 - 1974 351C 4V is better-off with a Blue Thunder manifold and a Demon Carburetors #1402020VE carburetor rather than the factory induction (including the De Tomaso single four barrel induction).
-G
That could be harmful to the environment. It should be recycled.
The carb recommended by Ford through the "Muscle Perts" program back in the day, was the 4181. That is the 850 double pumper with the 50cc secondary pump.
Their information claimed it was worth 15hp over other carbs on that engine. Probably any double pumper is but blame John Vermersch (now head of the Ford "Racing" aftermarket parts program) for these writings and recommendations. That was his job back then.
Dan Jones dyno testing "program" showed that the Blue Thunder needs runner modifications. It showed that the manifold has four good runners and four "bad" runners.
His partner in that program was able to port the manifold to somewhat equalize the runner flow balance. That you need to be very knowledgeable and talented to be able to do, not to mention having a flow bench at your service.
Back in the day I ran the Shelby version of that manifold and in the days of only a "seat of the pants dyno test" available found that the Edelbrock Torker was worth several 1/10s in the 1/4 over the Shelby.
The Shelby manifold was more suited to a Cleveland running an automatic transmission. On a manual trans car, especially using a solid lifter cam like the Boss351 version, it really is a dog, and not a Greyhound either.
With original iron 4v heads now, maybe the "Ford" script manifold to run would be the "Ford Motorsport" A341? That is a FORD modified casting of the Edelbrock Torker manifold with stuffer plugs built into the port runners at the ports to match the A3 heads.
I have one here to show you if you want to see it.
Since it is a modification of the Edelbrock molds, identical on the outside EXCEPT FOR THE ELIMINATION OF THE CHOKE HEAT CHAMBER UNDERNEATH, it will still bolt up to the 4v Ford iron heads. It has to be worth some horsepower over the regular Torker and certainly crispins up the throttle noticeably.
They are not common and not easy to find but they are worth the effort. It is arguably the best Ford logo single 4v manifold available.
With that manifold you can then take your pick of what Holley carb to run with. I found that a 4179, a 750dp was about right. Be warned though that carb is very rich at idle and will smart your eyes from the fumes.
Of course all of this depends on the camshaft you are going to use. Forget about the original 4v CJ hydraulic unit. But that all starts up another thread? Not to mention a "tuned" set of headers? Smiler
What George has said about camshafts, I would have to agree with. Factory cams are much more comfortable to live with in everyday driving. High performance cars in general, are not what you want to drive everyday as your everyday car. I'd rather drive a truck to be honest with you.
The "stock" Pantera's engine characteristics were a consideration of this delema. It was intended as an "everyday" use sports car, and for many was their only car.
For racing though, it is really too mild stock.
