What is the proper way to route the coolant to and from the radiator? It appears that the current flow is water pump pulls from top neck and coolant returns to the bottom? Seems incorect to me? Can someone more knowledgeable way in?
...Thermodynamics Dictate: HOT into the TOP...Cool Out Through the Bottom! That's The way I Did It!! And it gave 190F on the Veglia in the Desert at 90 MPH...180F RS Thermostat (and restrictor plate). Outside Temp was 118F!
Many, MANY here will Disagree!! Now let 'Them' Dispute That!
MJ
P.S. if you research, ALL Cars Foreign and Domestic, Do IT This Way! You will Find the Pantera is the ONLY Car that has it Reversed, Period!!
The "water pump doesn't pull from the top and coolant returns from the bottom." The return IS the water pump. HOT in the top and Cool OUT of the bottom TO the water pump.
@panterapatt posted:The "water pump doesn't pull from the top and coolant returns from the bottom." The return IS the water pump. HOT in the top and Cool OUT of the bottom TO the water pump.
...Congrats! You have it Correct!
Thank You for Posting. Now, look at Others.
MJ
I thought this drawing was better. while the dashed lines for continuation are not include from tube to radiator, but assuming tubes are shown at true elevation.
notice the vent tubing 37 from top tube goes to top of radiator. (to midigate the fact the outlet is near center to allow top of radiator to fill.
another thing to remeber, the original radiator had a vertical seperator in the end tank for front / back flow path. the ford recomedation was change sperator to horizonal giving the bottom / top path. expaning why thermal switches for fan are also FUed
and my "engineering" background is that the pump pushes throug engine / radiator back to its "suction" inlet
Various Factory literature shows it both ways, which was a bit confusing. So on a 550-mile trip to a 'Vegas Fun Rally and back some years ago, I tried it both ways in our '72, changing over at a racing friend's home in Pahrunp, NV.
The car ran the same temps both ways and the trip each way was long enough to fully assess any problems. Including past Marlin-Jacks home in the southern NV desert. So based on that I'd say the routing makes no difference in a street Pantera. YMMV-
@bosswrench - Agreed, should not matter.
